Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 06-07-2005, 09:37 AM
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Default Tips for swapping engines?
Well, the time has come. The FRPP 347 is fully accessorized. The only items that are swapping from the old engine to the new are the oil pressure and water temp sender. I even tried ordering new senders, but the have not come yet. Any tips on swapping the engine on a completed car?
I will be using an engine leveler. Does the radiator need to come out? Should I jack up the rear?
Tom
Old 06-08-2005, 06:37 AM
jams's Avatar
Cobra Make, Engine: B & B
I have never swapped an engine. I would just make sure you have a good lift, plenty of hands on stand by to help maneuver the engine. I would take everything out of the way that I could Radiator etc. The more things out of your way the less likely you are to have a mishap. It is a lot easier to remove things before then during the process.
You might also want to post this question in another section of the forum (Tech)
Jim
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
Old 06-08-2005, 06:23 PM
GREENSNAKE's Avatar
Default engine swapping
Hi Tom! I swapped my engine out 3 times in my other cobra, If you plan on using a cherry picker (foldable crane hoist) I found out it was easier to take off the front tires and go in from the side since the engine sets too far back against the firewall it was lot more manuverable. And i would go ahead and take the radiator too i was able to get it with it in car but it did rub and flattened a couple cooling fins . Hope this helps Tom! Lonny (greensnake)
Display Modes
