Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 12-05-2006, 11:21 AM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
Default trunk prop rod pic
anybody have a picture of a finishline prop rod installed in a trunk (boot)?
the older i get the faster i was.
Old 12-05-2006, 11:30 AM
Dwight's Avatar
Smile prop rod
I can get a pic later today.
Dwight
Old 12-06-2006, 01:22 PM
pmfranke's Avatar
dwight , did you take off one of the brackets ?Thanks
Old 12-07-2006, 07:37 AM
Cobra Make, Engine: LA Exotic
I am interested in the pic also..I put the prop rod on my Christmas list..so I am sure Mrs Claus will accomodate me.
cant seem to find the pic in this thread..can you sent it to me at:bmi@hamilton.com...thanks
Old 12-07-2006, 08:17 AM
Dwight's Avatar
Smile prop rod
Did you get the pics I emailed you?
Dwight
Old 12-07-2006, 08:24 AM
FUNFER2's Avatar
Hey Dwight, me too please. Do you know if they can be chromed plated, or will the sliding of the mechanism just scratch it off ?
Kevin
Old 12-07-2006, 09:12 AM
pmfranke's Avatar
no pics recieved,yet.
Old 12-07-2006, 09:49 AM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Send a message via AIM to EarlsflyinCobra
I have the same rods as FL (came with my kit) but am thinking of replacing them with the piston type. I have seen these on some other Cobra's and they look like they would work better. Does anyone have a part number suggestion for this type?? Thanks, Earl
Old 12-07-2006, 04:50 PM
Dwight's Avatar
Default prop rod
You did not say what you wanted with the prop rod pics. But here is a few that we have in our Cobras. In the last pic you will see Coach used both types of rods. We mount the rods with self tapping screws and sometime bolts thru the bottom of the trunk. Be careful about drilling thru the trunk deck. I hope this helps.
Dwight
Old 12-08-2006, 05:26 PM
pmfranke's Avatar
thanks, i wanted to see the mounting points like the blue car. If the botom mount is high or low. the trunk lid front or back. it looks like both bracket were used. thanks again. Peter
Old 12-08-2006, 09:34 PM
Rick Parker's Avatar
[IMG][/IMG]
I reduced the length a small amount.
Old 12-13-2006, 10:04 AM
pmfranke's Avatar
thanks rick and dwight. a picture always helps me . on the trunk lid did you just tap into the fiberglass ridge ? was there metal in there?
Old 12-13-2006, 10:16 AM
I made a formed metal plate from aluminum and used structural adhesive to attach it to the underside of the fiberglass.
