Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 04-09-2007, 11:18 AM
Cobra Make, Engine: B&B,351/385hp,Silver/Black stripes
Default B&B anti-sway bars
I am looking to add front and rear sway bars. Does anyone know of a good vendor or donor car? What would be the bar size and width needed? Does anyone have installation pictures? Any help appreciated.
Old 04-09-2007, 11:30 AM
Clois Harlan's Avatar
I had mine made by a company in Oregon and I used a 1" bar. I think if I had it to do again I would go to an adjustable type sway bar that are sold at most of the local speed shops with splined ends. Here is a post I made some time ago when I bought mine:
http://www.clubcobra.com/forums/show...front+sway+bar
"Let's roll"
"Be part of Something Good
Old 04-09-2007, 07:19 PM
Thanks, The old posts have a lot of great info. Do you run a rear bar? Also have you replaced any of the rear trac bars with poly bushings?
Old 04-09-2007, 08:32 PM
MacGyver's Avatar
Cobra Make, Engine: B&B 5.0 roller W/carb & T-5 WC
I too have the same questions. How about the B&B front sway bar? I have heard any fox 5.0 configuration rear bar will work. Can anyone verify this?
Old 04-10-2007, 06:57 AM
I tried a rear bar but I didn't like the feel so I took it off. I also replace all my bushings in my rear trailing arms with the poly bushings EXCEPT the UPPER control arms that mount to the pumpkin, I kept the butyl rubber ones in there for their ability to flex a little more. Leaving those top ones in seemed to help with handling and ride comfort when not on a track.
Clois
"Let's roll"
Old 04-10-2007, 09:29 PM
Cobra Make, Engine: B&B 351w
I used a front swaybar from an 86 camaro. works great. picture of it in my photo gallery.
Dusty Rhodes
