Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
Old 05-27-2007, 06:59 AM
Cobra Make, Engine: B&B
Default Front Sway Bar
I wanted to install a front sway bar and tried several junk yard take off's but did not like the look or fit. Made (6) tries with mock-ups using conduit before I came up with this design. Could not figure out how to load a photo so the pics are in my gallery. Used 1" 4140 chrome moly bar stock and bent to shape in a 20 ton hydraulic bender. Drilled and threaded the ends for attachment. Had the bar heat treated at local custom spring shop. Mounted to the bottom of the front cross member. Only 4 holes to drill. Removed the B&B cap screw lower shock mount and replaced with a longer grade 8 bolts. Only fit issues was to cut down the Heim ends to maintain ground clearance. Total cost under $100.
Old 05-29-2007, 10:39 AM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
Thanks for the info. How long till its driving? like to here how it handles and what kind of wheels and tires you end up with. PETER
the older i get the faster i was.
Display Modes
