| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
08-15-2007, 05:46 PM
clutch cable
I have a TKO 600 from Fortes which came with what I was told to be the proper clutch cable. I am using the B&B supplied peddle box and the clutch cable seems too short to me. Has anyone run into this problem, anyone have advice or pictures?
08-16-2007, 07:55 AM
AR
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
I used the stock mustang clutch cable and it works great. I have a few pictures on my site. Let me know if you want closeups.
08-16-2007, 08:16 AM
Where did you get that clutch hump? That is my problem!
Corey C
08-18-2007, 07:30 PM
Ca
Cobra Make, Engine: B&B 351/402 Fi roller everything
look at my pics for a clutch mod that realy works well.easy to push and no frayed cables.
the older i get the faster i was.
06-22-2008, 08:32 AM
IL
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Can you give details on your clutch modification? I just had my cable break on me, and am considering hydraulic or a modification.
08-24-2008, 03:33 PM
Ca
well my modifcation did not work cable snaped clean 4" from the peddle ass.only had 2000 miles on it. can not figure out why.maybe it untwisted the cable causing a weak point ? dont know
08-25-2008, 04:37 PM
co
Cobra Make, Engine: B&B...351/393w
hydraulic
Love my hydraulic conversion, cost under $200.
08-26-2008, 03:57 AM
AR
Wfieldin, were did you get it and can you share any details?
I haven't had any problems with mine, but I don't have the miles on it that most do.
08-26-2008, 04:28 AM
co
Hydraulic conversion
Started here, had to modify and add to transmission bracket to work. Used a wildwood master and slave from summit racing. Total cost was around $200.00
http://midnightdsigns.com/Mustang/HYD%20Clutch.htm
08-27-2008, 03:49 AM
AR
Thanks wfieldin, this looks like a new project!
08-28-2008, 01:15 PM
AR
Cobra Make, Engine: B & B , 351W 400+
Clutch - Hydraulic
This works too.
10-04-2008, 06:47 AM
FL
Paul Proefrock on his Hurricane Build..has an inexpensive hydraulic setup that works Great.........
http://www.proefrock.net/3x2CSX/Build/clutch.htm
