Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 05-29-2009, 09:54 AM
ndpace's Avatar
Cobra Make, Engine: B&B with Motorsport Crate 302
Default side vent induction
I was looking at mounting my side louvers and had it facing the wrong way. It made me wonder if putting them in the wrong way, then plumbing that "forced air" to the carb would work.
Has anyone seen this or tried this? Any feedback on if it would work?
Thanks, Jim
2020 Shelby GT500
93 Mustang Cobra
66 B&B Cobra
67 Mustang Coupe
63 T-bird Convert
47 Fordor Flathead
01 F350 Crew Cab V10
Old 05-29-2009, 12:17 PM
SF_SN888KE's Avatar
Cobra Make, Engine: Cutting Edge Replicas, 427 World block SBF, TWM Injection
I thought the hood scoop was for forcing in air? My guess is that the side louvers are to help vent the air coming up from under the chassis and cool off the exhaust heat. Make a custom air cleaner set up ala Ram Charger style for the hood scoop, or use the two front vents and snorkles. of couse if you leave the lovers the way they are and drive in reverse, that could work too!
Ron; SF_SN888KE
Cutting Edge Replicas 427
Shell Valley Daytona #27
Old 05-29-2009, 07:12 PM
CHANMADD's Avatar
No comment!!!!
Old 05-29-2009, 07:20 PM
Default Love Hath No Fury...
Originally Posted by SF_SN888KE View Post
...of couse if you leave the lovers the way they are and drive in reverse, that could work too!
Any time I see lovers driving in reverse, I always leave them the way they are....
Old 05-29-2009, 10:16 PM
SF_SN888KE's Avatar
Freudian slip ...
Ron; SF_SN888KE
Old 05-30-2009, 09:33 AM
bobcowan's Avatar
heT side vents wre edesigned tole t hot air out. Over the years, lots of people (including CS) discovered they didn't work very well. Hood vents work a lot better.
Some people have also tried using the side vent as an intake port. That doesn't work well either. It's a small hole. And it's a flat hole. At speed, it becomes a negative pressure area.
If you enlarge the hole and put a scoop or dam behind it, it would work.
Old 05-30-2009, 10:32 AM
Originally Posted by bobcowan View Post
The side vents wre deesigned to let hot air out. Over the years, lots of people (including CS) discovered they didn't work very well. Hood vents work a lot better.
The key is to have a pathway for the air across the primaries. Doing this is in your wheelwell is one way (and it looks cool too).
Old 05-30-2009, 02:06 PM
bobcowan's Avatar
I did the same thngi withmy car. But I did it to cool the foot boxes. It works really well, too. Mine are a little smaller, too.
Old 05-30-2009, 02:14 PM
That black duct tube at the top of my picture feeds the foot boxes with fresh air from the front of the car. Some guys put little in-line fans in the duct to blow it harder, but I haven't found that necessary.
Old 05-30-2009, 08:07 PM
Rwillia4's Avatar
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
the standard side vent area is a low pressure (suck area) that is suppose to pull the heat out of the engine bay. You want a high pressure area to feed your carb. The headlight area has the highest pressure area but obviously you probably want to use your lights. Which would leave the radiator area.
Old 05-31-2009, 07:56 AM
SF_SN888KE's Avatar
Cobra Earl makes the fresh air box kit with fans, but also sells dual brake duct boots which can be used to also feed the air cleaner or push heat out towards the side louver vent to reduce under hood heat.
http://www.cobraearl.com/products/
http://www.cobraearl.com/ProdPics/Dsc00071b.jpg
http://www.cobraearl.com/ProdPics/BrakeDucts2.jpg
or use the big oil cooler duct:
http://www.cobraearl.com/ProdPics/OilCoolerDucts4.jpg
Finish Line also sells the Brake Ducts .. just add some 3" ducting and a plastic blast gate to close the vent.
http://www.finishlineaccessories.com...t.php?cPath=25
Ron; SF_SN888KE
