Old 08-15-2011, 08:40 AM
willow1308's Avatar
Cobra Make, Engine: Backdraft Cobra #340, Reflex Silver with Ghost Stripes/Rondells, Polished Roush 402R, TKO600
Unhappy New ignition installed...Cobra still running when switch turned off!
Last month I started a thread about my BDR continuing to running after the ignition was turned off...
It was suggested I should replace the ignition with a brand new Painless ignition switch...
I purchased the new switch...and installed it...drove the Cobra several miles...started and shut down the engine several times...seemed to solve the problem...
I have not driven my Cobra again till yesterday (it's been too hot this summer to enjoy the Cobra much)...so I took the Cobra for a short spin at night...pulled back in the garage...turned off the key... the engine continued to run...I turned off the battery kill switch...turned off the lights...and eventually the engine stopped...
So...I spent a few minutes starting and than turning off the ignition switch...no problems...everything worked great...engine shut down...I could not duplicated the problem again...
OK now...I'm scratching my head...any thoughts on where I go next to permanently solve the problem...it seems to only happen when it's rather hot outside...and the lights are on...but that could be just a coincidence...
Thanks for the assistance...
Randy
BDR#340
Old 08-15-2011, 09:16 AM
Is your electric fan running when it does this? If so, you need a fan relay....otherwise the fan will backfeed voltage into the ignition.
Old 08-15-2011, 10:18 AM
willow1308's Avatar
Thanks for the response!
Yes...during all the years I've owned this Cobra...I've always had the manual over-ride toggle switch for the electric fans engaged all the time...thus the fans run all the time...
Old 08-15-2011, 10:23 AM
Turn the fan off and make sure it stops spinning before you kill the ignition...see if that helps.
Old 08-15-2011, 10:47 AM
undy's Avatar
I had the same problem with my Cobra and read where installing a diode in your alternator's wiring to stop voltage feed-back and the subsequent run-on problem. This is a common problem with "home wired" alternator systems. It sure cured my woes. There's even instructions included with MSD's boxes that talks about this.
Too many toys?? never!
Old 08-15-2011, 11:21 AM
willow1308's Avatar
The perplexing question I have is...I've owned this Cobra for 4 years...and never had this problem until recently...
Old 08-15-2011, 12:32 PM
Have you been doing any carb tuning?
Old 08-15-2011, 02:21 PM
willow1308's Avatar
No carb tuning...why do you ask?
Old 08-15-2011, 02:48 PM
There are several symptoms of run-on, and there are some things that you can do to the carb to cause it. A high idle can cause run-on, along with a vacuum leak, etc.
Old 08-15-2011, 03:06 PM
Cashburn's Avatar
Backdraft Racing Dealer
Don't think we are talking about run-on here are we? You are actually experiencing a condition where you turn the ignition switch off... yet the car keeps running like it is still in the on position? Right? Like it will keep running until you physically kill it somehow?
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 08-15-2011, 03:07 PM
We may not be Jay, but I wanted to cover all the bases.
Old 08-15-2011, 06:48 PM
willow1308's Avatar
Hi Jay...yes...you're correct...the Cobra keeps running like the ignition is still in the on position...
Old 08-15-2011, 08:45 PM
Rick Parker's Avatar
MSD Ignition
Old 08-16-2011, 04:27 AM
undy's Avatar
Originally Posted by Rick Parker View Post
Thanks Rick, that's what I was talking about...
BTW... mine ran for 4 years as it was wired before it started doing it.
Old 08-16-2011, 06:12 AM
priobe's Avatar
The diode in the alternator is bad, which is why it just started to do this.
Wire up a relay to solve this problem. If you add a diode again, it will eventually happen again.
Old 08-16-2011, 10:49 AM
willow1308's Avatar
Thanks for the info...any additional details you could provide would be helpful ...what type of relay...where do I splice it in...
Old 08-16-2011, 11:00 AM
priobe's Avatar
Here is a link that describes the wiring for the install
How To Properly Install An Electric Fan
Any 30 amp relay will do. I prefer Bosch if you can get one
