Old 11-16-2011, 03:07 PM
Cashburn's Avatar
Backdraft Racing Dealer
Exclamation BDR1049 - Gets Blown in the Speed Lab
Ryan's BDR1049 is about to go back to dyno for final test and tune. He picked it up a few months ago with a nice little Ford Racing 306 crate engine. Brought it back to us 2 weeks ago for a Weiand 174 Series supercharger install. Waiting for the weather to clear so we can drive out of the parking lot...
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 11-16-2011, 05:54 PM
Cobra Make, Engine: Sold Backdraft #488 Roush 427R
Jay it sounds and looks good.
What is the HP gain?
Does this also increase the torque?
Peter
Old 11-16-2011, 06:33 PM
Cashburn's Avatar
We baseline dynoed it at 300 rwhp. Will see what it makes now. Current pulley is making 4 psi. We have another pulley to try 6 psi. Key is to keep it safe and driveable. This setup on a 302 (short deck) is with no hood modifications.
VINTAGE MOTORSPORTS
Old 11-16-2011, 07:08 PM
fordracing65's Avatar
Thats bad ass, I love power adders and so do ford small blocks, sweet ride.
PRIDEnJOY
Old 11-17-2011, 10:16 AM
dallas_'s Avatar
Cool, looking forward to seeing the results.
Nice work on the plumbing also. Looks clean and professional.
Old 11-17-2011, 01:49 PM
SpecOp1's Avatar
Cobra Make, Engine: Backdraft #1058
Great looking car Jay....have a SC in 1063 future ...but down the road....cant wait to see dyno numbers...Bill
"He Who Dares , Wins"
Old 11-17-2011, 02:42 PM
I say 350wrhp with a ton more tq where it will matter.
PRIDEnJOY
Old 11-19-2011, 10:26 AM
Cashburn's Avatar
413 RWHP without the air cleaner. We need to find a better air intake system. Torque is a straight line and 381 peak.
Also have a fuel supply issue to sort out.
VINTAGE MOTORSPORTS
Old 11-19-2011, 07:05 PM
aa909's Avatar
Wow, a 30%+ increase is impressive. Not what I would have guessed.. Nice
Old 11-19-2011, 07:27 PM
413 rwhp, come on now
Old 11-19-2011, 07:40 PM
Nice numbers, I was way off.
PRIDEnJOY
Old 11-20-2011, 12:25 AM
Cashburn's Avatar
Once we get it adjusted I will post the chart.
VINTAGE MOTORSPORTS
Old 11-20-2011, 12:29 AM
Cashburn's Avatar
That carb hat is too low profile for the carb with a choke. We determined a 9" extreme filter will clear if we trim the hood opening under the the scoop. Imagine a turkey pan setup without the turkey pan
VINTAGE MOTORSPORTS
Old 11-20-2011, 12:35 AM
Default If you re looking for more power
Cashburn Jay If you are looking for more power with getting crazy Look at the Snow water mister system. You can run a 50/50 of water alcohol raise the timing, lower combustion temps and pickup another 40-50 HP and 30-40 FT of torque with only timing and jet change. An A/F meter would be hiden for checking the setup at cruise to not have a lean out. The other thing is blower bang, Don't run the motor at WOT and then shut down the throttle to idle. Does the blower have a small blow up valve? If so then you are all right. Heat is not your friend. Adding a couple of small blowers to the fender ducts will help remove some of it to cool down under the hood. Nice setup Good luck Rick L.
Old 11-20-2011, 08:16 AM
Cashburn's Avatar
Thanks Rick. We seem good on temps. Of course we are not testing at 95 degrees this time of year. The Snow setup is something we were talking about the other day. I think that would be phase 3 for the customer. The most amazing thing we saw on the dyno was a nearly level torque line from 3800-6000 rpm.
VINTAGE MOTORSPORTS
Old 11-20-2011, 09:22 AM
Senile Club Cobra Member
Is that the M-6007-X302 engine?
Ford says this under the info for that motor...
IMPORTANT WARRANTY INFORMATION! Power-adders such as superchargers, turbos, or nitrous not recommended. Use of power-adders voids the warranty. See Ford Racing Boss series of crate engines such as M-6007-X302B or M-6007-X302E if you plan power-adder enhancements
Ford Racing Performance Parts
rick@autoventureusa.net
Old 11-20-2011, 12:18 PM
Cashburn's Avatar
What is your point?
VINTAGE MOTORSPORTS
Old 11-20-2011, 12:46 PM
Juat asking if that is the engine. I am sure if so the cutomer is aware of the change in waranty.
Just want to know which Ford Racing 306 it is. I normally would not post in he BDR area as I don't belong here, but it is the only way to ask this question. Perhaps Ford is being a little cautious with the 306 if it can handle a supercharger.
Honest Jay, no agenda.
Old 11-20-2011, 02:20 PM
Cashburn's Avatar
Customer is aware. This kit is designed for a stock bottom, it's up to you how you pulley it. This was an add on when the customer said "please sir, may I have some more.". The car already had 2k miles or so.
Since we are the installer we assume the liability.
Have nothing against you posting here at all. Did not take it that way. The Ford warranty is only as good as the installer as I am sure you know, and that motor is an incredible value when you see some of the parts used inside.
We will likely pull it back a little in the end to keep it balanced. You would not believe the driving experience before and after...
VINTAGE MOTORSPORTS
Old 11-20-2011, 03:40 PM
[quote=Cashburn;1162351].
QUOTE]
Jay,
Quite agree. We are delivering a roadster model to Boston next week with that engine which is why I asked. The car is an anniversary gift to his wife who "has always wanted one" and I doubt she will want/need more scoot. Just wanted to know if that was the engine and how it held up.
