Old 07-22-2014, 11:24 AM
Cobra Make, Engine: Backdraft #832
Default Clutch Slave Cylinder Bracket
After replacing the fluid in the clutch I noticed that the bracket holding the slave cylinder moved as the clutch was depressed. I removed the bracket and push rod and replaced it with a custom bracket made from 1/4" 4130 steel. I purchased from Rosenhill their adjustable push rod. This gives me much more control over the clutch operation. I had the original bracket duplicated and manufactured using a water jet to cut the steel and then bent to the exact spects. If interested contact me at jimbo01@embarqmail.com
Old 07-22-2014, 06:01 PM
Cobra Make, Engine: BDR, 302
Was the original bracket what was supplied by BDR? If it will work on a T5 then I am definitely interested and will take one and will PM. Thanks.
Old 07-23-2014, 11:34 AM
Default Backdraft Clutch Slave
I should have been more specific in the thread. My car has a 427 with a TKO 600 5 speed. The bracket I understand would fit a TKO 500 or 600. Rose Performance parts in Texas has a bracket for the T5 and the adjustable push rod. I a impressed with the push rod as it gives you the ability to preload the throw out bearing. The push rod I have from Backdraft is not adjustable.
Old 07-23-2014, 12:04 PM
Thanks.
