Like Tree3Likes
  #21 (permalink)
Old 09-26-2014, 06:50 AM
Cashburn's Avatar
Backdraft Racing Dealer
Originally Posted by jimbo01 View Post
I do not understand "stock" gauges. Most have VDO, Autometer or Smith's gauges. If you have and Autometer speedo and tach most likely you have Autometer guage package.
See my reply above.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
  #22 (permalink)
Old 09-29-2014, 05:59 AM
Cobra Make, Engine: Backdraft #832
Spent some time Saturday correcting the ground problem on two gauges. Mounted a ground bus bar and installed separate grounds on the gas gauge and volt meter. Found the volt meter is giving an incorrect reading. The voltage at the gauge is 12.5 volts and the gauge shows less than 12v. Not sure if the problem with the water temp gauge is solved. Know more when I start it up again.
Rate This Thread:
