November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree1Likes
  • 1 Post By Rjscharer
Old 11-12-2014, 05:00 PM
Cobra Make, Engine: Backdraft
Default Wildwood remote reservior leak
Put a Wildwood remote clutch reservoir in last month. Noticed a large
puddle on my garage floor and traced it to a leak around the o ring at the
base of the reservoir bowl. Anybody else have this and how did you eliminate
it?
Thanks
rcobrakit67 likes this.
Old 11-13-2014, 06:14 AM
poor design. remove top of reservoir, clean o-ring surfaces, coat o-ring with "seal all" reassemble and it will never leak again. seal all is impervious to brake fluid.
Old 11-13-2014, 06:32 AM
lovehamr's Avatar
Stolen Avitar
I've used quite a few Wilwood M/Cs with the plastic res. and have never had a leak there. Was the plastic neck heated before it was installed on the M/C? Is the clamp in place and tight? If it was forced onto the M/C without heating maybe the o-ring got mangled? Just seems weird man.
Steve
Old 11-13-2014, 06:46 AM
Dwight's Avatar
Smile
I agree, poor design
I have several of them on the back shelf that leaked.
I changed the ones in my GT 40 to metal ones because of leaks..
Dwight
Old 11-13-2014, 07:12 AM
jwd's Avatar
jwd jwd is offline
Dwight
All three of mine leaked. It seems to be a very common problem. I threw them in the trash and used CNC ones from Forte.
Old 11-13-2014, 07:54 AM
Tom Cimino's Avatar
Cobra Make, Engine: Everett-Morrison 427SC 302 smallblock. 431 stroker in the works, tremec 3550
The wire clamp that comes with the reservior can cut or crack the plastic neck. I swapped the wire clamp with a hose clamp when I replaced the reservior on my M/C.
Old 11-13-2014, 09:46 AM
Rick Parker's Avatar
If the "O" ring gets "nicked" while installing reservoir or if the clamp is over tightened this can happen. Mine have been on a LONG time with no issues? Just saying......
Rick
Old 11-19-2014, 08:36 AM
Cobra Make, Engine: Backdraft #832
I took a look at the Forte master cylinder. Not sure how one would mount this is in a Backdraft car unless they have one not on their web site. I am looking for a metal one to use with the Wilwood clutch cylinder using a remote reservoir to use AN 4 stainless line. I have looked at several but not sure which to purchase yet.
Old 11-19-2014, 11:24 AM
Steve
Agreed...
Old 11-20-2014, 08:05 AM
Used All Seal as was suggested here with a new o ring. Problem solved....no more
fluid seeping out.
