Like Tree9Likes
Old 07-18-2016, 02:25 PM
Bernica's Avatar
Senior CC Premier Member
Yup. I would much rather have one personal engine builder that I could count on and call if I had a problem and not deal with a morass of corporate BS, only to end up in a time-sucking hole and stuck with a lot of costs that are "exluded".
Stearman likes this.
Old 07-18-2016, 02:51 PM
Stephen Crosten's Avatar
Default 427sr/tw
Another perspective; my SPF was built in 2010 and has logged just over 26000 miles. I have experienced no mechanical problems and the engine (427sr/tw) does not burn or leak oil. Needless to say I am very pleased with the power plant. However, should I ever replace it I will probably go with a Blykins engine. He is very available to discuss issues and make suggestions, and from what I have seen makes a damn fine engine at a reasonable price.
Bernica and Stearman like this.
Old 07-18-2016, 03:43 PM
RodKnock's Avatar
Here's a couple more threads from over on the GT40s Forum:
Roush engine failure... - GT40s.com
Roush 427IR: Camshaft & Distributor Gears FAILURE - GT40s.com
Old 07-18-2016, 04:16 PM
Cobra Make, Engine: Backdraft Cobra RT3, Roush 427R Crate Engine, Tremec 6-Speed Transmission
I purchased my Backdraft R3 Roadster new in year 2015 with a Roush engine (427R dyno tested at 550 HP and 528 FT-LBS Torque) and a Tremec T56 6-speed tranny. I have driven the vehicle for a year and a half and have observed no engine leaks and only slight bucking at lower RPMs (below 1800). I have no oil burning problem--the dipstick showed no measurable loss in oil after the first 1000 miles and no measurable loss since. I live in the Phoenix and have not incurred any heat problems while driving in the hot summer heat (well over 100 F). I must say that I am quite pleased with the Roush powerplant in my Backdraft Roadster. I guess I got a good engine. Sorry to hear about all the 'nightmare' problems with other Roush engine owners.
Old 07-18-2016, 08:05 PM
JWilly's Avatar
Cobra Make, Engine: Superformance, Roush 402R and CSX 6029
I have the Roush 402R (got it in 2007). It does not leak oil and I have had no mechanical issues. It does buck some if it gets much below 2000 rpm. In that case I drop down a gear and problem solved. I can only speak from my experience but I would gladly purchase another Roush engine in a heartbeat.
Old 07-18-2016, 11:31 PM
fordracing65's Avatar
I think the problems were more with their FE lineup.
PRIDEnJOY
Rate This Thread:
