Like Tree6Likes
  • 1 Post By Trickcobra1
  • 3 Post By Cashburn
  • 2 Post By jualwatt
Old 08-21-2016, 11:48 AM
14vision's Avatar
Cobra Make, Engine: Backdraft #964, Roush 427, T56
Default Fuel Fumes ?
Question for the group regarding fuel fumes. I have roush 427 carbureted motor and I had this issue before and it hasn't happened again until now. I keep my cobra in my garage and awhile back I noticed after parking I smelled a lot of fuel fumes within my garage and into the house. I pull in and immediately **** car off not to let it run for any period of time. I originally thought maybe some leftover fuel in carb caused this,
Issue didn't seem to resurface until yesterday. Yesterday i did fill up my tank probably close to full. When I got home pulled in shut car off and that's it. Now even today a day later a still have very strong fumes smell in garage and within house. The only thing I did do was fill up tank. Could this be issue maybe I filled it up to much and doesn't vent properly?
Thiughts or comment greatly appreciated as my wife will be a happy if we can find a resolution.
Doug
Old 08-21-2016, 12:14 PM
Trickcobra1's Avatar
Cobra Make, Engine: Factory five
Most likely filled the vent tube. You can run a charcoal canister on the tank to eliminate this from happening.
Joe
Old 08-21-2016, 01:15 PM
14vision's Avatar
Thanks Joe. Where do I get one of those? Also is this because I filled the tank up to much?
Old 08-21-2016, 02:54 PM
Cashburn's Avatar
Backdraft Racing Dealer
Never completely fill the tank on your way home. Especially when it's probably 100 degrees...
Gaz64, BDR0572 and Trickcobra1 like this.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 08-21-2016, 02:35 PM
For my build I bought mine from eBay.hard to say could have filled to high or depending on the filler neck it only takes a little bit for it not to breathe.you just need a basic one, it's around 30-40 dollars. Very simple to hook up,I'm not able to post pics yet for some reason keeps saying moderator has to approve.when I'm able to I could send a diagram for hook up or you can just google it. It's 2 vacuum hoses 1 off motor and 1 off tank both go to the canister and will never smell again.
Joe
BDR0572 likes this.
Old 08-21-2016, 02:53 PM
DWRAT's Avatar
I had the exact same problem.
Smell fuel after fill up.
Ended up being the top seal on the tank where the sender and fuel pickup goes into the tank.
Most likely there's a access hole in your truck that will allow you to see it perfect.
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
Old 08-21-2016, 04:58 PM
tpatodd's Avatar
Cobra Make, Engine: BDR #997, Roush 427SR+TW
I tend to run mine down to around a 1/4 tank (who knows how much fuel is actually left) and then I add 10-gallons. Never any more. My needle shows ~9/10 full so I rinse and repeat.
Old 08-21-2016, 06:57 PM
14vision's Avatar
Thanks everyone good information..
Old 08-22-2016, 05:24 AM
jualwatt's Avatar
Cobra Make, Engine: Backdraft 1134, Roushcharged Coyote Aluminator NA
I have found that most pumps shut off when the tank is completely full (IE do not pump another penny in and stop). If it is hot out and you fill the tank with cool gas (from being stored underground), the gas will expand in the tank as it warms. I have had it start to leak overnight after a fill due to this (gas station less than 1 mile from the house). What I do to avoid this now is either fill up at a station maybe 10 miles out or go for a short 8-10 mile ride after filling. It has never happened again.
Julian
cdnus and Zeke like this.
