Like Tree7Likes
Old 10-22-2016, 09:13 AM
bobcowan's Avatar
Default Differential Strength
For my third Cobra, I'm taking a serious look at Backdraft. I have about a million questions.
1. How strong are the diff and axles? How much power can you put through it and still maintain reliability?
2. Can the chassis accept a 460 Lima motor without mods?
ront49 likes this.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 10-22-2016, 03:20 PM
Cashburn's Avatar
Backdraft Racing Dealer
To the best of my knowledge, and based on watching this forum for 14 years or so, I am only aware of one differential breaking and I believe it was on the track. I should say I'm aware of 2, the other did not have oil in it. We have put 900hp through them with some simple modifications. The standard setup from the factory is good for under 600hp.
Yes a 460 will fit and we have headers available. We did opt to make our own larger primary headers for a Roush 588 install.
ront49 likes this.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 10-22-2016, 05:16 PM
Gary Bowman broke the rearend in his BDR. He was out on the street, but if I remember right, it was under a huge traction loss and then suddenly hooked up. That engine was around 650 hp if I remember correctly.
So where's the other 999,998 questions?
ront49 likes this.
Old 10-22-2016, 05:46 PM
bobcowan's Avatar
What simple mods did you make. My last car was making a little more than 500 on the chassis dyno. I'd like to do better this time. And I don't exactly drive it easy. Donuts make me laugh out loud.
Coming, be patient.
ront49 likes this.
.boB "Iron Man"
Old 11-04-2016, 06:55 PM
Jus Cruisin's Avatar
Non owner here wondering about the standard rearend. Frank assures me there is little need for the limited slip on the street. I guess go with it and swap it out down the road., I just don't like the idea of "peg leg" burnouts that might occasionally happen. What are the thoughts from owners? Thanks!
Looking at Backdraft
Old 11-04-2016, 08:38 PM
Cashburn's Avatar
I thought he broke it due to a loose bolt? But I don't know for sure. I'll dig up dyno info...
VINTAGE MOTORSPORTS
Old 11-04-2016, 08:58 PM
Cashburn's Avatar
Coming, be patient.
Just saw this. If I forget to reply tomorrow just email me.
VINTAGE MOTORSPORTS
Old 11-04-2016, 09:24 PM
I just changed from the 3.46 factory open differential to a 3.91 posi, and it is like a different car. All the chugging and bucking from lagging at low rpm's is gone, and I can actually get decent traction when I hit he gas in 1st and 2nd now. I would order the car with the posi if I had it to do again.
Old 11-05-2016, 05:25 AM
mln385's Avatar
Cobra Make, Engine: BDR
My opinion is the car is safer to drive the rear stays put and does not want to come around as easy. Ordered mine with the LSD .
Old 11-05-2016, 05:32 AM
Cobra Make, Engine: Backdraft 1048
Is an E36 M3 LSD a direct swap on a RT2 car? 4 Bolt drive shaft?
Backdraft 1048
Old 11-05-2016, 05:47 AM
Millsy's Avatar
Cobra Make, Engine: Backdraft, LS3
If you are going to have n engine put in with high H.P., say over 400 H.P. then i would suggest LSD. I went with a 525 H.P. motor and we decided the posi LSD was the way to go. My backdraft car is still being built but I have found the cars i have driven with LSD are more controllable when putting down alot of power to the ground. JMO
Old 11-05-2016, 06:09 AM
What kind of rpm are you seeing at 70 mph in 5th gear with the 3.91?
Old 11-05-2016, 09:24 AM
bobcowan's Avatar
I think a car like this without some kind of limited slip is silly. Gotta have it. They're so light, and any amount of power can easily beak the tires free. Esepcially if traction is a little bit limited.
Clutch types work pretty well, but can sometimes cause a push on corner exit. On the street that's not a big issue.
If I was going to be racing, I'd order the standard diff and save the $2,100. Then swap it out for a worm gear, like TruTrak or Torsen. About the same money, but more geared towards racing.
.boB "Iron Man"
Old 11-05-2016, 11:26 AM
I'm sticking with the stock rearend for the build. I'll track down a used lsd rearend at a recycle yard or off eBay. More cost effective.
Old 11-05-2016, 01:06 PM
Cashburn's Avatar
For E36 Diff?
Ozzie Goat likes this.
VINTAGE MOTORSPORTS
Old 11-05-2016, 01:14 PM
Cashburn's Avatar
I don't have the timeline exactly. Not sure if these numbers were before delivery or when it came back because he had pulled the engine and redone something.
Run 3 it was: 535RWHP / 461.64T
Run 9 it was: 548.53RWHP / 485.95T
ront49 likes this.
VINTAGE MOTORSPORTS
Old 11-05-2016, 03:43 PM
I am at 2200 RPM at 70 mph with the 3.91 rear end and the T-5 transmission (I just re calibrated the speedometer).
Jus Cruisin likes this.
Old 11-05-2016, 03:46 PM
Broken Diff
460 Windsor or move to a big block
Old 11-05-2016, 05:24 PM
Grey 65's Avatar
[quote=blykins;1407989]Broken Diff
Not a broken diff. someone did NOT tighten 6 bolts correctly and the half shaft came loose and hit the diff cover cracking the diff cover...
Kevin....
Old 11-12-2016, 06:32 AM
Mother's Avatar
Cobra Make, Engine: Boss Replica Motors BB 460 by New Generation Engines
I have been using a 1971 Ford Torino 9 inch for many years. The 3.46 ratio with an Auburn ratchet spool has never given up. I check the lash every second year just to be safe. My engine produces 740/ 680 at the finals. No problems.
