Old 11-15-2017, 08:06 AM
Sledge's Avatar
Cobra Make, Engine: BDR #168 427W 69+K miles and counting
Default Anybody know the fuel tank depth...
...at the sending unit for the metal tank in early BDR's? I'm looking to install a capacitance fuel sender, which needs to be a specific length above the bottom of the tank, and would like to avoid having the car out of service while I drop the tank, measure it, order the part, wait for the part, etc.
Thanks for any help.
Bill
"If your work speaks for itself, don't interrupt"
Old 11-15-2017, 09:16 AM
Cobra Make, Engine: Backdraft #832
I purchased one from Wema USA in Ft Lauderdale. I remove the tank and measured from opening to the bottom of the tank. You need to know the ohms values for the gauge your using in order to order one. They make a 2 wire sender which is one of the best I have found. Do not purchase the 3 wire sender as they are junk. You can also measure the sender you have in the tank. Simple to remove the tank. Be careful with the bolts attaching the sender as they are easy to strip out. If needed you can purchase a stainless split ring to go under the tank opening to screw the sender to.
Old 11-15-2017, 05:47 PM
Good info Jimbo. Do you have the brand and PN of what you installed?
I need to change mine as well (never goes past 3/4).
I'm still considering just installing a signal compensator. (still need to put an analog multimeter on it and see if the OHM sweep is smooth 1st)
Classic Instruments Store / SN34
https://www.speedwaymotors.com/Class...ce,230181.html
Allows you set zero 1/4, 1/2, 3/4, full regardless of sender/gauge combination.
Old 11-16-2017, 07:33 AM
I will ck out the web site. I know which one I bought. Most of these units are mfg for the marine industry and are super quality. Will post later the #.
Old 11-16-2017, 07:41 AM
Took a look at WEMA site. You would need to contact them and give them the ohms range for your gauge and the length you need. If you don't know the ohms you can contact the gauge mfg and they will be happy to let you know this info. The model # is SSS/SSL.
Old 11-16-2017, 09:10 AM
Excellent info. Looking at the site the SSS/SSL are Reed switch operation and not capacitance. Not a big deal but are more along the lines of click I'm @ 3/4, click I'm @ 1/2, etc...
Marine Liquid Level Sensors by WEMA USA, Inc.
Liquid Sensors - Marine Diesel, Fuel, or Water Level Sensor
I need to get off my butt and T/S some more before I move forward.
I'm in the same boat as Sledge. Would rather have the parts on hand already.
This site piqued my interest as the capacitance senders are trimmable for length.
Hardin Marine - Fuel Tank Gauge Senders
Old 11-16-2017, 10:30 AM
Sledge's Avatar
Thanks Spdbrake in re the trimmable senders info.
Bill
Old 11-16-2017, 11:33 AM
The sender I purchased reads from empty to full correctly. No mater how much fuel I have in the tank it reads correctly on the gage. I purchased a 3 wire sender from a comany in Tampa and it did not work at all. Finally through it away.
Old 11-16-2017, 11:42 AM
Thanks Jimbo, you're correct on the Reed switch operation not being clickey in operation. Sorry if I came off as a jerk in my response. I hate typing / texting, hard to emote.
