Like Tree2Likes
  • 2 Post By eschaider
Old 05-29-2018, 07:09 PM
Cobra Make, Engine: Backdraft - Iconic 427
Default Aluminum tank capacity
I have a backdraft built in 2015 with optional aluminum tank. Issues with fuel guage and trying to figure out the tanks capacity. I have been told 19 or 17 gallons.
Old 05-29-2018, 11:38 PM
eschaider's Avatar
Check out this thread > How Big is My Tank?
Ed
Old 05-30-2018, 06:40 PM
Tank is not easy to measure, odd size. Hoping for a reply from cashburn.
Old 05-30-2018, 06:55 PM
Millsy's Avatar
Cobra Make, Engine: Backdraft, LS3
18 gallons, thats what Jay told me mine was, it was built in 2016.
Old 06-05-2018, 09:54 AM
Winchester67's Avatar
Cobra Make, Engine: Backdraft #91 with 345 HP 302
My gauge does not work either...correction. When it is full it is 3/4 on the gauge. Then you can drive forever, then suddenly the gauge drops. But since when the gauge drops I still have like five gallons, it is that point I start looking for a Hy Vee. (I am in Missouri and Premium Hy Vee gas does not contain any corn.)
My long suffering wife, a CPA is bothered by the fact my gas gauge is not accurate and my speedo only works sometimes. So I need to fix the gauge or the speedo. Either which is cheaper than a new wife.
Old 06-05-2018, 10:37 AM
eschaider's Avatar
Not necessarily your situation but sometimes a new wife is the happier path. Just sayin' ...
Ed
Gaz64 and Millsy like this.
Old 06-05-2018, 06:50 PM
RockBit's Avatar
Pheagles - if you PM a sketch of your tank with dimensions to me I will calculate your tank volume.
Chris
Old 06-05-2018, 07:44 PM
Winchester67, same exact issue I have with my fuel guage. Did testing and guage is working and sending unit is putting out the correct home. Plan to pull tank down and check the float. Likely bent or sticking on well area in tank.
Old 06-05-2018, 11:43 PM
lomdel's Avatar
Cobra Make, Engine: Backdraft RT3
I have a Backdraft built in 2017/2018 with the stock plastic tank with 70 litres capacity as mentioned by the factory representative. The stock BDR fuel level gauge is also irregular and dips and drops as I accelerate and brake and cruise, so the correct fuel level is usually an average of the needle movement...
I have also learnt the hard way to never fill the tank to the brim right before parking the car in the garage. The fuel sometimes seeps out the top through the fuel-pump- and sender-unit gaskets a bit. Rather fill her up just before a drive.
Old 06-06-2018, 02:00 AM
Cobra Make, Engine: built the molds and body composite construction
Suggest you look at moellermarine.com for their non-swing arm marine sending units.
Working on a vertical shaft the gauge does not show the great movements of a shifting fuel level due to changing levels from cornering and braking etc. Make sure your gauge works with a 240-33 Ohm sender or you will have to replace the gauge. They come in lengths that are in one inch increments and as I remember you want one that is one inch from the bottom of your tank for the proper length.
