Old 02-21-2020, 11:30 AM
The fronts are are still stacked under the peg drive adapters.
This is a photo of #1591 front brakes
https://s235.photobucket.com/user/jd...tyjxe.jpg.html
I'd PM 1swtride who owns this car regarding the back though since I don't know if the rears will fit over the integral hub/peg drive assy. He's sheared a hub already so should be familiar with the assy. I'm pretty sure they will fit over the hub as the bore looks larger for the rears on the Iconic site. https://www.iconicparts.com/wilwood-brake-kit.html
Old 02-21-2020, 01:30 PM
hawretre's Avatar
Cobra Make, Engine: Backdraft #1799 5.0L Gen 3 Coyote
Thanks spdbrake for posting the link to that brake pic. It illustrates my point perfectly. While a new car #1591 still has the old hubs and separate pin drives on the front.
This is my front brake assembly. The pin drive/hubs are one unit front and rear.
Makes it pretty hard to stack the rotor under the drive.
Old 02-21-2020, 03:59 PM
I see as the kit instructions are for the older peg drive adapters I doubt it will work for your application.
Granted you could measure the disc hat bore and offset requirements and get Willwood make or sell you a set of hats. Your current calipers look to be the stock E36 units so at least those are not an issue.
But then your on the path. And modifying an already expensive kit with no ability to get a refund.
It may be easier to just return it and get a de-bugged kit from Iconic once its available.
Old 02-22-2020, 12:20 AM
LudicrousSpeed's Avatar
Cobra Make, Engine: ...
Thumbs up
Give Vintage Motorsports a call or PM Cashburn on this site. They know these cars inside & out and should be able to give you a definitive answer.
- Just call me Speed
