Like Tree7Likes
  • 2 Post By lnfletcher
  • 1 Post By twobjshelbys
  • 1 Post By cycleguy55
  • 1 Post By spdbrake
  • 1 Post By IMLost
  • 1 Post By Quentin Z
Old 01-26-2021, 11:50 AM
Default brake light on vrs pedal distance
I have a backdraft,#595, when I push on the brake pedal the brake light does not come on until I am almost to the end of the distance that the pedal goes. I was told to put a external switch on the pedal arm but if I do that so the switch turns on the light, I wont be able to continue to push the pedal down to apply the brakes. Should I try to bleed the the brakes to see if the pedal comes up higher, or is something else needed?
Old 01-26-2021, 12:50 PM
lnfletcher's Avatar
Put a normally closed switch at the return of the pedal with a return spring to keep it engaged until you brake. Then it will not matter what the travel is on the brake.
ndpace and cycleguy55 like this.
Old 01-26-2021, 03:25 PM
cycleguy55's Avatar
Right, like Infletcher said. Something like this one:
These often have three pins and can be wired either normally open or normally closed. If you look closely you can see the pins on this one are labeled (L-R): C (common / hot), NO (normally open) and NC (normally closed).
Wire it so it's normally closed. The circuit will be open when the roller is pressed against the brake arm and when you press on the pedal the arm will move away from the roller and close the circuit, energizing the brake light circuit.
https://www.digikey.ca/en/products/d...SS-5GL2D/17243
Brian
Old 01-26-2021, 03:43 PM
twobjshelbys's Avatar
Be aware of contact current ratings if the lights aren't on a relay. You want a switch not a fuse.
Yetiman likes this.
CSX4005LA
Old 01-26-2021, 04:03 PM
what about using a door jam interior light switch?
Old 01-26-2021, 04:38 PM
Steve this thread should help.
Member True007 had a good quick fix for a plunger normally closed switch with bracket and PN
Stopped for no brake lights !!
Pics here https://www.dropbox.com/sh/pplph2b2p...n8UXn1oFa?dl=0
Old 01-26-2021, 04:59 PM
Thank everyone for the help, getting mechanical switch tomorrow.
Old 01-26-2021, 07:18 PM
cycleguy55's Avatar
Yes, good point. I've put a link in to that switch. It's rated at 5A 125VAC - I have no idea what the DC rating would be. Regardless, there are plenty of switches out there that would work.
Brian
Old 01-26-2021, 07:25 PM
cycleguy55's Avatar
Standard Motor Brake Light Sending Units SLS66
https://www.summitracing.com/parts/smp-sls66
Probably available at virtually any auto parts store.
IMLost likes this.
Brian
Old 01-27-2021, 01:03 PM
Quentin Z's Avatar
Cobra Make, Engine: Backdraft #272, 351W
Great pix! That guy must be a genius!
Old 01-27-2021, 05:03 PM
Sorry Quentin is that was your fix and I misnamed it. I remember saving the Dropbox pics link and thought I tagged the genius correctly, lol
Quentin Z likes this.
Old 01-30-2021, 02:10 PM
IMLost's Avatar
Cobra Make, Engine: BDR #178 United Speed World Special
Too many times too many make it far mor complicated than necessary. Simple bracket with a momentary contact switch. 1 bracket. 1 hole, 1 switch. 2 wires. 1 fix. Done go drive.
Doing and driving what other people dream about!
Old 02-02-2021, 12:19 PM
spdbrake, how did you get or what did you use to get the wiring from the engine bay to under the dash through the drilled hole to the switch?
Old 02-02-2021, 01:06 PM
Quentin Z's Avatar
Just disconnect the wires from the pressure switch and leave them zipped up somewhere around there. Use a jumper wire with matching male connections from that point to the new switch. Heat shrink, so they don't ground out & complete the circuit. Drill the hole up from the foot well, and run the jumper wire down through it to the new switch. Crimp on the female ends and connect in to the new switch. Viola.
Old 02-05-2021, 03:05 PM
Ok guys, I installed the mechanical switch, did not work, I reconnected the original brake line to the switch on the reservoir , it doesn't work. Do I need to replace the switch? Fuses are good.
Old 02-05-2021, 03:12 PM
Gaz64's Avatar
Can you post a photo of your switch installation Steve?
Old 02-08-2021, 11:47 AM
Quentin Z's Avatar
Do the lights come on when you touch the wire ends together?
BDR0572 likes this.
Old 02-08-2021, 12:56 PM
cycleguy55's Avatar
When you use an electrical tester, do you have current between either of those leads and a good ground? If not, then you'll have to trace the circuit back to the fuse box.
BTW, when I first received my car (not a BDR) the stop light switch only worked when the ignition was on. Obviously that would be an immediate failure on any safety inspection and one of the first deficiencies to be addressed.
Brian
