Old 06-14-2021, 08:30 PM
SBSerpent's Avatar
Cobra Make, Engine: BDR build #983, FRM 392
Default Rear wheel offset
Comparing the position of the rear wheels in the fender wells, I notice a disparity between DS and PS. My PS rear tire sits inward of the fender by almost 1" more than the DS tire. By inward, I mean towards the differential. It doesn't look obvious at first glance but once you focus on it, you can see the slight disparity. This is on a 2011 build #983. Would this just be a case where 'nothing is perfect' on these replicas and its just a matter of the body not properly positioned on the frame? Anything that can be done about it?
Old 06-15-2021, 04:35 AM
This BDR thread from 5/24/21 may help a bit.
space out wheels
Old 06-15-2021, 06:26 AM
aa909's Avatar
Are you sure it's not the camber? even a 1 degree difference between the two sides would make the top look visually more tucked in on one side vs the other.
You can confirm this by looking at the bottom of the wheels, does the PS (which sits more inward at the top) look like it sits more outward at the bottom vs the DS?
Thanks
Art
Old 06-15-2021, 09:00 PM
SBSerpent's Avatar
Nope. Not a camber issue.
Old 06-15-2021, 09:50 PM
Cobra Make, Engine: Unique 427 Side Oiler
I have a Unique 427 and it has the exact same issue. When I didn’t notice it, I didn’t notice it at all, but once I noticed it and measured it it seems like I focus on it constantly. But I’m over the issue now I’ve looked at so many Cobra’s and lots of them have the same issue.
Old 06-16-2021, 01:16 PM
ERA 626's Avatar
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
It should be fairly easy to figure out where the issue lies. if its the body being off or the rear end being off. Measure from a point on the rear suspension like the brake rotor to the chassis on both sides, it should be the same. I also assume you tried swapping the wheels to confirm it is not an offset issue. I am not familiar to the backdraft rear end. but you should be able to figure it out in a few min with a tape measure, measure the brake rotor to the chassis on both sides.
