| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
4Likes
Post By tpatodd
2
Post By spdbrake
Post By BDR0572
06-19-2022, 09:16 AM
FL
Cobra Make, Engine: BDR #997, Roush 427SR+TW
Roush Air Filter Replacement
Since #997 was built in 2008 I figure it might make sense to replace the Air Filter in the Roush Assembly versus cleaning. Anyone successfully locate this part?
I went through the "find filter by size" on the K&N website ... nada. E3515 is the closest.
The only option at Iconic is to buy the whole assembly. No filters.
06-19-2022, 12:04 PM
CA
Cobra Make, Engine: SPF832, 466cid
Closest to what? Post your filters LxWxH here so that people can give you some advice.
06-19-2022, 01:38 PM
FL
Has K&N printed on one side and this part # on the other: C147AB - 1
Outside dimensions: 14 1/3 x 7 3/4 x 2 1/2
Inside dimensions: 12 1/2 x 6 x 2 1/2
06-20-2022, 07:22 AM
I too have had a devilish time finding any filter taller than 2” in this oval size. 3” would be ideal but I’ll take even 2.5” if available (as a standalone filter only and no housing).
06-20-2022, 10:05 AM
CA
If you go the standard cobra oval, the below dimensions and link should help.
Tony Branda Oval 20.8 x 9.5 x 2.25
S&B Oval Air Filter Element (Tall)
https://store.cobranda.com/sbovairfielt.html
K&N
E-1963 20.8 x 9.5 x 3
E-1960 20.8 x 9.5 x 1.8 (Standard)
06-22-2022, 05:19 AM
FL
I just ordered the E-3515 and will let you know how it fits.
06-26-2022, 08:29 AM
FL
Update: The 3515 won't work for me. I need the 2 1/2" of filter height. At 2" (3515) the screw does not tighten enough and the assembly is loose. I think a washer might look tacky.
06-26-2022, 09:55 AM
So the screw is a few threads too long using the 2.0" filter? Can you take 3-4 threads of the screw with a dremel or belt sander?
Or buy a shorter screw?
https://www.mcmaster.com/screws/
06-27-2022, 03:25 PM
TX
Cobra Make, Engine: BDR, Roush 402R
I have the same filter and housing bought new bolt (counter sunk Allen)at Lowes polished it look like chrome sealed with clear coat, anything taller rubs hood
