Like Tree10Likes
Old 01-16-2026, 05:38 AM
BDR BDR is offline
I have a Backdraft RT4 built in 2022 with an aluminum tank and autometer gauges. My fuel gauge was all over the place and never that accurate. I installed the Holley Easy Level sender but couldn't get it to work. It would read the fuel level then drop to empty. Tech support at Holley said it was because I had a "shiny"gas tank and the reflection was causing the issue. They suggested painting the inside of the fuel tank... not!
I ended up replacing the OEM sender with a KUS151324 6 inch stainless steel reed sender, for around $40 bucks, and it works fantastic. The install was simple and now I have accurate fuel readings on my gauge.
Quentin Z and CompFi like this.
Old 01-18-2026, 08:11 AM
Sledge's Avatar
Cobra Make, Engine: BDR #168 427W 69+K miles and counting
Good information BDR, thank you!
Bill
"If your work speaks for itself, don't interrupt"
Old 01-18-2026, 11:24 AM
Sledge's Avatar
BDR: which fuel tank do you have in your Backdraft? Internal pump setup or external?
Bill
Old 01-19-2026, 07:37 AM
BDR BDR is offline
I have the aluminum tank with internal pump.
CompFi likes this.
Old 01-19-2026, 07:56 AM
Sledge's Avatar
Thanks BDR. I purchased mine yesterday.
Bill
