02-24-2006, 07:58 PM
LED Lights
A few have asked about the LED light thread that went missing, when the forum DB went.
I will post more details when I take some more pic's. But here are some details on Jay's message board.
http://www.vintage-motorsports.com/f...bcfa8392ff1bdd
02-25-2006, 05:40 AM
Ill
Cobra Make, Engine: BDR #177 Carbed Ford Small Block
Big thanks Shaun. This is not only a cure for something a lot of guys have been struggling with, but also a better design than using standard bulbs. Can you please confirm part numbers for the LED's and relays. Thanks again.
Tis better to burn out than to fade away. So "Lite 'Em Up!"
02-26-2006, 03:57 PM
LU
Cobra Make, Engine: Backdraft
It's more than good..... with this combinatiom of amber and red we could pass the controls without problems, because here in europe rear turn lights must bright in amber....but looks much better in red when lights are off.
Alfonso
02-26-2006, 04:58 PM
Wi
Cobra Make, Engine: Arntz/SBC/Jag
I am using LED brake tail and turn signals in my Cobra for over a year now.
I experimented with many of the different ones on the market to find the brightest ones, and settled on the ones from http://www.cyclegadgets.com/Products/?cat=LIGHT
but i believe that Custom dynamics http://www.customdynamics.com/motorcycle_led_bulbs.htm carries the same ones (with the side facing LED's), and they also have these really trick ones with a red brake light in the middle with a circle of LED's around the outside called Dynamic Clusters for a directional indicator which would give you four bright brake lights And blinkers.
If you have the minx style tail lights the LEDs are a must have item ta make them far brighter than a regular lamp (because they don't have reflectors in them) and also as a safety item because they don't heat up. There was another thread that was lost about people having fires start from things in the trunk getting into the lamp because it isn't sealed in back.
02-27-2006, 07:29 AM
LED are from Custom Dynamics
Running light & Brake light are part 3208-18 (1.85" Diameter Replacement Cluster RED)
Turn Signal & Brake light are part #3209-38 (1.85" Dynamic Cluster LED Turn Signals)
http://www.customdynamics.com/motorc...c_clusters.htm
These have pigtail for turn signel and hard wire for brake. If you look at my pic's you will notice I cut off the pigtail and hard wired them.
(pigtail is the end that fit's into a normal bulb socket)
Relay, (just about any 12v relay will do) I used this
http://www.radioshack.com/product/in...entPage=search
RS part #275-241
Also, when using LED's of this sort, you generally need to add a load, otherwise the turn signals will flash quickley (just like they do when one bulb is blown). I did not need to do this on my BDR. But you may need to, depending on what kind of flasher relay BDR used of other cars.
If you do, then this is what you would need from Custom Dynamics #4810 @ $15.25. I have one, because I fully expected to need it. so I know it fit's and works, but I did not need to install it.
Shaun
02-27-2006, 06:10 PM
OK...Here are some pic's.
I can;t use a camera for ****, so these are not that good, (espically the color differance between red and amber), but you get the idea.
-- Base Line (nothing on) --
-- Running Lights --
-- Running Lights + Right turn (couldn't catch it on full brigntness) --
-- Brake Lights --
-- Brake Lights --
-- Brake Lights + Right turn (I can't use a camera, looks red...but it's not, it's amber) --
Sorry. Not the best of pics, but you get the idea
Shaun
02-28-2006, 05:21 AM
Ill
Ordering mine today. Thanks for all the help Shaun. Who needs reverse lights?
03-27-2007, 03:52 PM
IL
Cobra Make, Engine: 396 long block, PROBE Forged Dished pistons 8.75 to 1 and Vic Jr. heads from Engine Factory. Tremec TKO. BDR#244 Sterling Gray/Silver stripes. 17in polished wheels, glove box and tonneau cover.
Hey guys,
I plan on doing this also. Jeff I'll touch base with you when I get this stuff in. THanks a lot Shaun! It is a HUGE help!!!
Sid
T.S.B. of The West Side Cobra Club
N.D.N.P.N.P.
03-31-2007, 09:07 PM
THATS COOL!!!! I want some.
03-31-2007, 11:08 PM
Shaun,
can you look at the web site you stated and give some more information as to which you ordered...I think they may have changed some numbers/names. I couldn't find the 3208-18 item number. I think they have changed to 5302-19.
thanks I look forward to being seen
04-18-2007, 09:16 AM
IL
Mine are in. Just got them done last night.(Thanks Mike!) I'm afraid to drive near O'Hare. Might get a 747 on my boot trying to land...they are BRIGHT! When looking in my rearview mirror at night I can see the lights brighten up all the signs! Jeff I'll be taking your advice and getting the turn signal ones also. Anybody figure out how to get all 4 on when braking? Question was probably already asked before...but figured I ask again.
Sid
N.D.N.P.N.P.
04-18-2007, 10:50 AM
IL
FYI BDR OWNERS: based on my cobra #244 For customdynamics.com LED Brake lights (lower lights)
BDR/LEDS
Red/Orange
Black/Black
Green/Red
sid
04-18-2007, 01:39 PM
GA
Cobra Make, Engine: SPF #821,Southern Automotive 427 Side Oiler w/2x4
Back up lites??? I think I need to look at the back of my car
Alex
04-18-2007, 08:12 PM
Cobra Make, Engine: BDR #491, Red with Black Stripes, 438 Windsor by Keith Craft Racing dynoed at 640hp, Street and Race Prepped.
Great info guys, thanks for sharing. I'll have to get a set for my car...
James
Radical Roadsters of Texas LLC
www.radicalroadsters.com
Backdraft Racing Dealer
281-804-5730
Watch out! You may get BIT!!!
04-18-2007, 09:21 PM
Cobra Make, Engine: Lonestar Classics, 302 stroked to 347; Metallic British Racing Green
One word of caution on this thread...I LOVE the LED idea and just installed on my Lonestar indicator/brake AND running tail lights, BUT I had to change the flasher units in the Painless wiring harness to handle the 'no resistance' LEDs. The replacements cost me $40 each from Summit (one for normal flashers, one for emergency flashers, OR you need to put load resistors across the LEDs (but everything I researched indicates these as a source of heat generation...JUST what we need in Texas in the summer...LOL). Here's the replacements I used in case anyone is interested and using a Painless harness
http://store.summitracing.com/egnsea...=KeywordSearch
Cave magister imperitus - Beware the inexperienced teacher
"No, I DON'T have an accent, this is how English sounds when it is pronounced correctly!"
04-19-2007, 07:33 AM
Since this thread has come back alive, and the origional install instructions from Jay's message board have gone, I've had a lot of PM's asking about the install.
Here are the pic's and wiring diagram, hope it's all obvious.
This is the brake & running light
This is the brake & turn signal
With this you have 3 options for the brake / turn LED cluster that will affect how the unit acts when you have BOTH brake and turn signal on. - 1 - No Relay (wire normally) - Brake on full intensity red all the time and turn flash amber (hard to see)
- 2 - Connect the dotted wire in diagram - Brake on high intensity when turn is not on, and low intensity when turn is on. (sort of flashing bright red to red & amber), this is also quite hard to see.
- 3 - Don't connect the dotted wire in diagram - Brake flashed from high intensity red to Amber with the turn. (This is the one I use)
Obviously you can use it like stock and just use 2 lights for running & Brake and 2 lights for turn, but I prefer the 4 for brake.
04-19-2007, 12:58 PM
Cobra Make, Engine: Hurricane Motorsports, 427w
Anybody know of a source for LED lights for square style S/C lights?
Hurricane Motorsports #1053; 427w
04-19-2007, 06:09 PM
Customdynamics make a buch of different options, I bet you can make one of their options fit. I use there stuff on all 4 of my bikes and the Cobra, most of what I use was designed for something else, but take some measurements and search their site.
They have LED's in strips that you can cut to your own length, and re-join, so I bet a few of those cut to the length of the lens and stuck together (to make up the width) would be perfect. you'd need to solder each strip together though.
04-20-2007, 06:46 AM
IL
Me Likey! Good job with the pics and diagram Sfreakes
Sid
N.D.N.P.N.P.
04-22-2007, 05:09 AM
oh
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
I installed these http://cgi.ebay.com/ebaymotors/1-85-...cmdZViewItemon LED's on my lower light, which is the running and brake light. For installation you have to drill hole in housing for the wires, shave a little off the sides of the screw post for clearance. For mounting I used double sided 3M foam tape. These LED have three modes "RUNNING LIGHTS... All LED’s are on at medium intensity. STROBING BRAKE LIGHTS... All LED’s strobe for 2 seconds and remain on at high intensity as long as brakes are applied to assure visibility and safety. TURN SIGNALS... All LED's turn on at high intensity." I connected my turn signal from my top light, which was turn only to the "TURN SIGNAL"...Now I have two lights for turning, LED running and LED strobing brake lights, and the brightness looks good. The quality of the LED product seems good, potting on both side of the PCB.
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
