Old 02-28-2006, 05:13 PM
wtm442's Avatar
Beam Me Up Scottie
Angry
Originally Posted by sfeakes
..... But, my car also has a problem, where once hot, the clutch works for s**t, the heat shield I made helped a lot, but it still has a problem of reverse. It's impossible to get into reverse without grinding after 50 or so miles.
Is this a common problem, or just one that I am having? I’m sure it’s because the clutch is not engaging correctly or fully.
Thanks,
Shaun
Reverse is not synchronized. Before shifting into reverse, shift into FIRST gear. This will allow you to shift into reverse without grinding.
Problems shifting in reverse
Been there ... done that ...
Warren
Rate This Thread:
