Old 03-31-2006, 09:29 AM
Dinobyte's Avatar
Cobra Make, Engine: Backdraft #395 from Vintage Motorsports; Valley Ford Specialist 487 FE with a TKO600
Default Ford FE Big Block in a Backdraft
I am close to chosing the motor after churning on the SMOG issues for so long. I wanted to find out if anyone out there has a Ford FE BB in a Backdraft. If so, could you share some after the fact information with us and what you learned during the process.
Dinobyte
Old 03-31-2006, 11:00 AM
1985 CCX's Avatar
FE in BDR?
I can only comment regarding the BDR with FE since I do not have a BDR. You may want to consider the torque and HP and how it will work with the BMW IRS. You may need to beef it up a bit along with front spring load. Too much of anything HP, Torque, or weight may result in issues......
jeff
Old 03-31-2006, 07:35 PM
Cashburn's Avatar
Backdraft Racing Dealer
Love it... it is more than up to the task if you need some evidence:
The total weight difference when you have aluminum heads, intake, pump, etc. is what 40lbs???
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 04-03-2006, 06:04 AM
Cobra Make, Engine: BDR #230 427 Big Block
I have a 427 big block in my backdraft #230 and have had no problems to this point approx. 580 H.P.
Old 04-03-2006, 03:18 PM
Dinobyte's Avatar
580HP!!! Whoa
What transmission and what is the final rear gear ratio on your set-up?
Also, how is the handling? Aluminum intake and heads/overall weight?
Dino
Old 04-04-2006, 05:01 AM
aluminum intake, pully's, water pump, not block, handles great, go to old post and I have pictures posted in there some where. Look up #230 and you will find it.
Old 04-04-2006, 05:02 AM
also have 4 speed top loader tranny and 373 gear ratio, that is ok wish I had 5th gear some times for the long drives.
