Old 04-06-2006, 09:05 AM
Cobra Make, Engine: BackDraft Keith Kraft motor...
Question Turkey Pan
Does anyone use a turkey pan with their air intake? Can you really notice a difference, or is it a waste of money and time? Thanx!!!!
Old 04-06-2006, 10:40 AM
jeffko's Avatar
Cobra Make, Engine: BDR #177 Carbed Ford Small Block
I don't know, but they look cool.
Tis better to burn out than to fade away. So "Lite 'Em Up!"
rdorman's Avatar
Renegade Nuns on Wheels
The turkey pan will more likely hurt performance because of the restriction in size to the air cleaner you can use. But they sure do look nice! I just went through the whole turkey pan, S&H phase and went back to a large air cleaner. I can certainly feel and hear the difference.
OhioCobraClub.com
LondonCobraShow.com
Old 04-06-2006, 10:46 AM
wtm442's Avatar
Beam Me Up Scottie
If you want a turkey pan to increase performance - do NOT use a stock version. Use any of the air cleaner "calculators" to determine HP loss (to get the correct sized cleaner), then make your own "over sized" pan. But do not forget to add a baffle to the front of the air cleaner!!!!
Warren
Old 04-06-2006, 11:59 AM
Cobra Make, Engine: Contemporary Classic CCX 3970: 1965 427 Cobra S/C, Shelby aluminum 427 CSX 290 (468 cu in) engine
Lizard Dude: Like Mr. Dorman, I too have gone through the wonderful looking, original S&H/turkey pan thing. Way too restrictive for my engine. Take a look at Superperformance's site secondstrike.com and use their air cleaner calculator to figure out just what you need. They mention a Ford oval air cleaner M-9600-R302, that will lose me only 3.2 horsepower at 6K RPM. It will fit my stock turkey pan, which will give me 5/8" clearance on the sides and over 1" on the ends. I do have concern is that 5/8" might not be enough clearance, as Warren implied. I plan on doing a chassis dyno pull to compare.
Also, Warren, you suggested the use of a baffle on the front of the air cleaner. Would you please elaborate? Thanks, Rich.
Old 04-06-2006, 01:44 PM
wtm442's Avatar
Beam Me Up Scottie
A carb likes airflow coming straight down thru the venturis/barrels. It does not like turbulence just above the throat, which can happen with an element that is in plain view thru the hood scoop on a Cobra.
Many racers use this on their open bodied race cars. This eliminates high speed air rushing across the top of the carb. Just a little thing most racers would worry about ... but not really necessary if you are street driving.
Warren
Old 04-06-2006, 02:39 PM
Talking
Thanx for the input, I think I'll just let it be! Thanx for all the input from all of ya!!!!!!!
