  #21 (permalink)
Old 10-22-2006, 03:35 AM
Cobra Make, Engine: backdraft racing 302 ford
I have some made and ready to ship
ED
Ed
  #22 (permalink)
Old 01-17-2007, 05:48 AM
jeffko's Avatar
Cobra Make, Engine: BDR #177 Carbed Ford Small Block
Ok guys, in simple terms can I use the dot 4 fluid in both brake and clutch after draining present fluid and not worry about residual fluid left behind?
Also, has anyone thought to use a hose shaped insulation as a heat barrier for the hydraulic fluid lines around the headers?
Tis better to burn out than to fade away. So "Lite 'Em Up!"
  #23 (permalink)
Old 01-17-2007, 02:03 PM
JayBar's Avatar
Cobra Make, Engine: BDR#078,408 Dart Block, TKO 600,Indigo Blue, White Stripe
Send a message via Yahoo to JayBar
Well..... I don't know. I did the opposite. I changed to DOT 3 in both systems.
There is a lot less fluid in the clutch system so a flush should be easier. But again I would flush the system with a lot of fluid so as to get all the old fluid out. Since the clutch system is so small you could remove both the slave and master an clean by hand.
I do use hose shaped insulation on both the brakes and clutch line.
JayB
Jupiter, FL
  #24 (permalink)
Old 01-17-2007, 06:19 PM
jeffko's Avatar
JayBar, what insulation did you use and where did you get it?
I am looking at a few options on Summit but would like to hear what worked for you.
  #25 (permalink)
Old 01-17-2007, 06:59 PM
JayBar's Avatar
Summit http://store.summitracing.com/partde...5&autoview=sku
On the clutch I re-routed the clutch line to run back from the master a long the top of the foot box then down the fire wall. I used a rubber type material hydraulic line (made up at NAPA). Then slid one of the above insulator sleeves over it.
JayB
Jupiter, FL
Rate This Thread:
