Old 10-15-2006, 03:31 AM
Clois Harlan's Avatar
What linkage are your running? Upper and lower controll arms, three link, or something else? What grade of bolts are you using (Grade 5 or Grade 8)? I have seen that Backdraft launch at the drag strip with slicks and never have a problem.
To remove the bolt get a cut off tool and a center punch and jack up the rear of the car and remove some of the load on that point. After cutting off the head of the bolt try and drive the bolt out which ever side is most convient.
Clois
"Let's roll"
"Be part of Something Good
