| 29 |
06-26-2007, 01:35 PM
backdraft wilwood slaves
Just had my first clutch failure. The shaft unscrewed from the slave and I understand from Reg this has been a problem. Simple solution is to remove the slave cylinder, unscrew the end cap, push the piston out to expose it. Idrilled a 3/32'' hole through the piston and shaft and installed a split pin (3/32) through the piston /shaft assembly. The hole is drilled through the CONE on the piston. There is no way this thing will come off again.
06-26-2007, 02:25 PM
Fl
Cobra Make, Engine: BDR # 165 392 Ford Crate 430HP
This is a common problem my clutch went out once and sure enough it was rod was loose in slave cylinder. Seems wilwood would put out a better product.
Like a kid in the candy store I just can't get enough
Current rides GT500 & Backdraft
06-26-2007, 03:36 PM
Cobra Make, Engine: Backdraft #101, 392 Ford Motor
Same Problem, Similar Fix
I incurred the same failure with my Wilwood slave cylinder! I was luckily within a mile of my home and I limped home in second gear.
I also fixed the shaft to the piston with a pin. Works great and no leaks!
07-01-2007, 07:13 AM
Cobra Make, Engine: BDR #491, Red with Black Stripes, 438 Windsor by Keith Craft Racing dynoed at 640hp, Street and Race Prepped.
Also, thread locker blue works great. I have used thread locker on the last few with no problems. Put it on the input shaft, retaining nuts, and mount.
Best of luck, James
Radical Roadsters of Texas LLC
www.radicalroadsters.com
Backdraft Racing Dealer
281-804-5730
Watch out! You may get BIT!!!
07-16-2007, 08:23 PM
 On Sat, found a puddle under the car. My Wilwood slave leaked out the front. I took the slave apart and also found that the rod was starting to back out. I think I will try thread lock first as I am not sure how easy it is to drill the cone for a locking pin.
Does have a guess at why it was leaking? I was thinking the seal has gone bad..?
Does anyone know what the Wilwood slave rebuild kit consists of?
Thanks!
07-16-2007, 08:26 PM
Will try posting the pic again...
07-16-2007, 08:34 PM
07-16-2007, 10:33 PM
Cobra Make, Engine: #42 BDR w/ a 408 KCM stroker
Mine I did kinda custom w/ Robert helping, will try to post pics but so far so good, think I'm running a different style than ya'll
2006 King Ranch F150 Supercrew
Personal vehicles-2007 Escape
2004 BDR #42 with a 408 Keith Craft Stroker, Crimson with Silver stripes
07-17-2007, 05:52 AM
This is our current setup that seems to be working extremely well. It took a lot of trial and error to settle on this final setup:
07-17-2007, 07:55 AM
Jay: Picture was a little dark so I couldn't see the details. Is this the setup I have on 481?
07-17-2007, 08:13 AM
Red Locktite #242 on threads into cup...........never worry again.
07-17-2007, 09:07 AM
MD
Cobra Make, Engine: BDR #212, 392 stroker
Neutral
Jim,
Nice cruise on Sat.
Your Cobra sounded great when you were leaving Billy's.
Looks like the next one is in St. Mary's, should be a blast.
Ned
07-17-2007, 10:12 AM
Yes, or extremely close.
07-18-2007, 07:43 PM
Mark, you can also get a rebuild kit for the Wilwood Slave cylinder at Summit Racing:
http://store.summitracing.com/partde...5&autoview=sku
It's fairly easy to rebuild.
Bests, James
281-804-5730
07-22-2007, 11:06 AM
Cobra Make, Engine: BDR#078,408 Dart Block, TKO 600,Indigo Blue, White Stripe
My Wilwood came apart twice, both times on the track. After the first failure I used locktite, but I think the brake fluid go to it.
I replaced the Wilwood with an almost identical product but at half the price form Speedwaymotors.com. The rod is "peened" to the piston.
JayB
Jupiter, FL
08-02-2007, 02:19 PM
Well today my linkage snapped (threaded stud that connects to the clutch fork) Was wondering and maybe you can answer this Mark Brye if I have to take apart the slave cylinder or can I just unscrw the rod and put a new grade 8 stud in it's place
08-02-2007, 05:12 PM
Cobra Make, Engine: Backdraft #395 from Vintage Motorsports; Valley Ford Specialist 487 FE with a TKO600
Guys, try the HOWE Racing slave. I replaced two Wilwood slaves with this one and have not had a problem since.
08-02-2007, 08:38 PM
I think I would take apart the slave cylinder. If you just take the rod out, and put thread lock on it, you may get threadlock on the seals. Also, you will not be able to keep the cylinder from sliping in the slave housing when tightening the rod. I would also buy the summit rebuilt kit if you have the Wilwood Slave. I think its like 13 bucks. Then you will have new seals and will not have to worry about any leaks in the near future. Hope I am understandable, had a few drinks
08-02-2007, 08:41 PM
If you need a Wilwood rod, I will mail my old one to you. Rod looks in good shape. Just the seal went bad in the slave cylinder housing.
08-02-2007, 08:54 PM
well I broke the same rod, so I am going to try to get a good grade 8 stud and that should solve the current problem
