08-16-2007, 06:10 AM
Anyone install a Brake Vacuum Reservoir?
Has anyone mounted a brake vacuum reservoir in their BDR? When I slam on the brakes really hard, my engine wants to die which causes my brakes to fail.
I have been playing with the rear floats on the carb in case I am getting fuel slosh. So far I have had no luck. I am going to try the little Holley carb “splash shield” but have not installed it yet. I tried the old trick of routing a hose from front to rear bowl carb vents and put a breather in the top of the hose. Trying this method filled my engine with fuel to the point of hydrolic lock in about 10 seconds. (Not fun).
The next thing I want to try is installing a vacuum reservoir. Looking for suggestions on engine compartment location and type of reservoir you may have used.
Thanks!
08-16-2007, 06:25 AM
Cobra Make, Engine: BDR #168 427W 69+K miles and counting
Mine's got one located on the right side of the engine compartment, between the front wheel and passenger footwell box, above the headers. I'm at work right now, can't remember the name on the bottle.
Hope this helps
Bill
"If your work speaks for itself, don't interrupt"
08-16-2007, 06:38 AM
Tx
Cobra Make, Engine: Auto Restoration and Service
Check out www.summitracing.com or www.jegs.com. They have reservoirs from $30-60 depending on looks. We have started to add belt driven vacuum pumps to our engines because we could not get a large enough reservoir.
Mitch
08-16-2007, 07:33 AM
MO
What sort of belt driven vacuum pump are you using?
Pete K.
Who is John Galt?
08-16-2007, 08:43 AM
Banned
I run one of the Summit units on my SPF. It maintains around 20-25in of vacuum and gives me that extra layer of protection. Removed the windshield washer bottle/reservoir on the driver's side fenderwell (never use it) and mounted it there. Easy stuff...
-Dean
08-16-2007, 08:58 AM
Tx
We use a Cardone #64-1009 pump. If you are using V-belts, it will take a Ford #E9TZ-2L487-A pulley. I have a picture of a serpentine install in my gallery.
Mitch
08-16-2007, 10:42 AM
MO
Thanks.
What pulley did you use with the serpentine belt?
Did you fabricate a mount or use one from another application?
Pete K.
Who is John Galt?
08-16-2007, 01:27 PM
Tx
We use the power steering pulley that comes with the Tru Trac setup for the serpentine. I am sure that a call made to Billet, March, Zoops, etc would find you one. The mounts will have to be made.
Mitch
08-16-2007, 06:10 PM
I never checked for a vacuum leak. I will check that tomorrow. I was checking out cannisters on Summit web site and will try that also. Will keep you all posted!
08-16-2007, 09:24 AM
ct
Cobra Make, Engine: Venom 351W Mild Cam 600cm Holley MSD T-5
Do you have a brake boster vacuum leak? Had that problem with mine.
joeg
