| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
10-30-2007, 07:57 AM
MA
Cobra Make, Engine: Backdraft Racing #183; 351W
Drive shaft yoke leaking
Sorry to pepper the forum with questions, but as I get #183 back in shape there are some things surfacing. You'll see I have no mechanics experience but have a buddy that's helping out with a garage/lift/experience. I'll learn one step at a time.
I have a leak from the back of the transmission...not big, but puts a 4" damp spot on the garage floor after a drive when I look in the am. My buddy looked it over..."it's the drive line yoke...It's tight to the seal so it's not leaking around the outside...it's probably a defect...I can weld it." OK, so I'm guessing there is a plug or hole in the middle rather than OD seal being worn. Whew.
Anyone had this? Suggestions? Thanks,
Tom
2+2=5 for very large values of 2
10-30-2007, 12:05 PM
Originally Posted by Tday
... I have no mechanics experience but have a buddy that's helping out ... "it's probably a defect...I can weld it."
Before you do anything, make absolutely sure that it's really the transmission that is leaking. For example, when my valve covers were weeping, the oil would seep out, almost invisibly, and track down the back of the block, over the bellhousing, to the Tremec, and then drip from the lowest portion of the transmission. If you didn't know what you were looking at you would have sworn that it was a leak from the transmission (but adding ultraviolet dye to the oil made it obvious to anyone). You can pick up a bottle of dye and a UV flashlight at AutoZone for about $15, and if that little damp area under your trans glows in the dark you can tell your buddy to put away his welder  .
10-30-2007, 12:14 PM
UT
Cobra Make, Engine: FFR with a 345-horse 302 Crate Engine
I used a new T-5 tranny in my car and when I first started driving it after the build I had a leak from the tail shaft. I assumed it was a bad seal and installed two or three seals in an attempt to fix the problem. The leak persisted. I finally replaced the slip yoke on the drive shaft with a new one. That fixed the problem.
I don't think a welder is the answer to your problem.
Jim Doak
FFR 2117
10-30-2007, 12:17 PM
MA
Good suggestion on the dye. And if it's a yoke, I'll surely want to replace it. I rolled my eyes at the welder idea too.
I'll figure out part no...if anyone knows it, please chime in. Will it be transmission specific, or BDR standard? It's a tremac 600. Thanks, Tom
10-30-2007, 09:06 PM
TX
Cobra Make, Engine: BDR #491, Red with Black Stripes, 438 Windsor by Keith Craft Racing dynoed at 640hp, Street and Race Prepped.
Tom, the input shaft on a Tremec TKO600 should be a 31 spline if I'm not mistaken. I think you can order a replacement directly from BDR. It may be almost cheaper to do it that way instead of running around searching out parts and trying to get someone to piece it back together.
Bests, James
Radical Roadsters of Texas LLC
www.radicalroadsters.com
Backdraft Racing Dealer
281-804-5730
Watch out! You may get BIT!!!
10-31-2007, 06:26 AM
CT
It is a standard 31 spline yoke. You can get it from any Mustang shop like Mustangs Unlimited in Manchester, CT.
10-31-2007, 07:33 AM
Ill
There is a plug in the back of the yoke to close the hole from broaching the splines---it ususlly has a freeze plug/ welch/cup /expansion plug in it. The trans is probably overfull and the excess is leaking pass the splines and out a imperfection in the plug. Welding it will work just fine and won't cost you a arm and leg( or even a rib, maybe a couple beers)
If the trans is overfull, the next place it'll leak is out the imput and onto your clutch
Jerry
10-31-2007, 10:21 AM
MA
Thanks guys. We'll take a look at it today and if I have to, I'll order new. He's thinking it's just an imperfection as well. Tom
10-31-2007, 06:36 PM
MA
OK, here's the deal...Jerry nailed it...the hole at the back of the yoke was leaking through the plug as he surmised. A touch up weld and we're on our way. Thanks, Tom
10-31-2007, 07:18 PM
Ill
Check your fluid level ---it may be too full
Did the rear flange register fit tight? I worked on a BDR that had tossed the driveshaft where the register was loose, new shaft assy was the same way--probably off by .020 or so
Jerry
10-31-2007, 07:37 PM
MA
It goes back together tomorrow am so I'll let you know. Yep...there are lots of little roller bearings aren't there. Roger on the fluid level. Tom
