Old 05-26-2021, 09:00 PM
Smile Anyone with a slabside I can sit in?
Does anyone have an ERA slabside I can sit in to see if I fit? I'm 6'3" and need to know if I have to cut off part of my legs to get in to the car.
John Hawkins
St. Helena
Old 05-27-2021, 05:11 PM
Just sit in any ERA. I think the interior is the same on them all.
Old 05-27-2021, 05:27 PM
The VW Bug style floor mounted pedals cut me off. I'm 6'2.
Old 05-28-2021, 01:26 PM
fastd's Avatar
I think ERA can lengthen the footboxes; there have been some large men that have found a fit in an ERA. I'm 6'0 and have no issues with my standard sized ERA FIA.
I did sit in a Unique Cobra once that my knees did not fit in.
Old 05-28-2021, 05:12 PM
Go here: 427 Frequently Asked Questions and scroll about half way down until you see a pic of a strikingly handsome older man in his ERA car.
Old 05-28-2021, 09:23 PM
Thanks all and particularly Pat T - that gives me some hope. Given the size of the bellhousing and the rearward location of the engine in the car (resulting in a wide transmission tunnel), are the pedals offset a lot to the left?
Old 05-29-2021, 12:35 AM
tkb289's Avatar
Hi John,
First off, welcome to the club!
You are welcome to sit in my ERA FIA, I am located in the south bay area.
I am 6’-4” and fit quite nicely in my FIA with the help from the fine folks at ERA. Some of the modifications were:
- Foot pedals moved as far forward as possible.
- Went with leather 427 seats with modified foam in the cushion so I sit lower in the car.
- The dash is a bit shorter than the originals, so I can get my legs under it. The drop dash in a slab side, may be an issue for taller drivers.
- The roll bar is slightly taller.
Similar to Pat’s experience, I also flew out to ERA for a test fit. I spent a few days there looking around and chatting with Peter, Bob and crew. It was a wonderful experience and they came up with a great plan. I have been very happy with the car.
Let me know if you want to get together and we can set something up.
- Tim
289 FIA --- ERA 2136
Build Log:
http://www.clubcobra.com/forums/era-...build-log.html
Old 05-29-2021, 07:01 AM
For cars made after late 2005, the answer is "No." In fact, I don't even notice any offset on my car, which was the second car made after the "big upgrade" of 2005. Now, my feet are 12EEE and I had the pedal shafts bent to space them out more. If you bought an already built car and wanted to replace the pedal shafts it would be a slight chore, but doable, and I'm sure ERA would just send you new shafts correctly bent to give you more fat feet room. Here is a nice pic of mine with the tape measure on them. The dead pedal is quite nice to have and I use it on every drive.
Old 05-29-2021, 05:06 PM
Excellent, thanks for the info and the photo. Probably 20 years ago I sat in an unknown-make 427 and found all the pedals so far offset to the left that it was uncomfortable to sit more than a few seconds - like driving sideways.
And Pat, thanks for the kind offer to sit in your car - I will see if I can pry myself out of the North bay.
Old 05-31-2021, 12:43 AM
tkb289's Avatar
Hi John,
Sent you a PM to set up a test sit.
- Tim
Build Log:
