10-02-2008, 01:59 PM
If it rains, I snore.
10-02-2008, 02:19 PM
Tom, I'm so close, but I won't have my car back this weekend. Hopefully, by next weekend. This is getting repetitive. Bucks is just a hop, skip and a jump from me, but I've got a soccer game on Sunday at 8:00 AM. Bummer.
10-02-2008, 03:49 PM
Looks like rain late Friday into Saturday AM at this point.
Sunday might work for me.
Scott - Why did you need to replace the pedal? Guessing there's some sort of bushing in the assembly that eventually wears out.
Doug
10-02-2008, 07:17 PM
Cobra Make, Engine: spf #1723 427w
With heavy feet like Scotts, Things are bound to wear out!!
Greg spf 1723
10-02-2008, 10:08 PM
Cobra Make, Engine: SPF 1474: 482 CI stroked tunnel port 427 with dual quads.
Scott, I was guessing the gas pedal would have worn out first
It really looks like Mother Nature is planning to rain on saturday's Cobra parade.
"Some things just get meaner as they get older"
.....Gumball Rally :-)
10-03-2008, 10:20 AM
I replaced the gas pedal shaft last year. Greg happened to have one that he never used. The pedal was still good.
I you look at the clutch pedal, there is three holes where you can connect the master cylinder. Its are normally hooked to the center hole. My center hole was worn, even though it wasn't much at the hole, the end of the clutch pedal had more then an inch of play. There is no bushing, and I tried to drill the hole bigger with out taking the pedal out, not a chance. So I put it in the bottom hole. You loose leverage, so it was hard to push the clutch in. WAY TO HARD. So the other day I put it in the top hole. Way easier to push the clutch in ( Greg said it is still way harder then his). The only problem is, you lose travel, so I had to raise the clutch pedal up about an inch and a half. So it was way to high. Tim from Dynamic's sent me a new pedal a week ago, so I installed it. I had to sand the hell out of the inside hole to make it fit.
Scott
10-03-2008, 10:41 AM
Scott
The only pedal you haven't replaced is the brake pedal...makes sense because you rarely use it.
Doug
10-03-2008, 02:18 PM
Come on. I resemble that comment!!
Scott
10-03-2008, 04:18 PM
Tom,
That would be good. I'm have to see how my daughters team does at the tournament Saturday, then that will dictate what time they play Sunday.
Scott
10-03-2008, 04:31 PM
Tom,
Scott
Sounds like District 2 Cup.
10-03-2008, 05:25 PM
Cobra Make, Engine: SPF #1019
Back to the subject at hand...
Saturday looks like rain, so I will probably drive my daily driver to the Rock House. However, I'd really like to get my Cobra out on Sunday...
I really enjoyed the drive over to Duarte's last weekend. I'd rather not deal with the bike's at Alices, and the drive to Buck's is too short. How about we drive over to Duarte's for breakfast on Sunday?
10-03-2008, 07:11 PM
Randy,
I'd be for a little trip. Where is Durante's?
Dave V
10-03-2008, 07:13 PM
Pescadero
10-03-2008, 10:37 PM
anyone have a set of 19# ford 88-93 injectors they dont want >? --fighting fuel maps with my 24#s
EDIT: SAT NIGHT --found some. thanks !
10-04-2008, 08:10 AM
Yep! They are playing in Palo Alto this afternoon. Late games this year. 12:30 and 5:30 in the class 1 division. Then possibly 8:00 am or 11:00 am for the first games on Sunday.
Scott
10-04-2008, 11:02 PM
No can do Sunday. My daughter has an 8:00 am game. If they win that, they will play again at noon.
Scott
10-05-2008, 12:42 AM
Steve = Down with flu/cold.
