| 29 |
03-02-2010, 01:11 PM
WI
Cobra Make, Engine: classic roadster 302
GT 40P heads
Is anybody using these heads on their 302?
03-02-2010, 01:35 PM
Mi
Many, Many, Many times.
The GT40 P heads come on SVO'S HI PERFORMANCE engines.
Dyno'd at 38 to 45 more hp than standard heads. More than made up for the weight difference!
03-02-2010, 04:07 PM
Using them on my 351. Good heads except the plug location is not favorable to my headers. Plug is too close for comfort. I am using the protective sleeves from DEI and 90* boots for the MSD plug wires that are routed below the headers to the front. Works for now but will be changing heads soon.
03-02-2010, 04:11 PM
WI
On a classic roadster, do these heads and CRs headers pose any space problems
03-02-2010, 04:25 PM
Ca.
I am using them on my 351 with 302 headers and no problem at all.
Terry
03-02-2010, 07:47 PM
Mi
As Terry says- no problems.
As boilerat says they can be hard on the boots - don't be afraid do do a little grinding on the edges of the headers to give the wires a little breathing room!
03-03-2010, 08:56 AM
DV, the spec sheet on my 351W lists the heads as GT 40 w/ 1.94 intake, without the trailing P, are these two different heads or ?
..........thanks
03-03-2010, 09:08 AM
Mi
Don,
Yes, you have the stock heads the "P" heads will have the "P" stamped on the right front side of the head.
03-03-2010, 10:30 AM
Either the GT40 or the GT40P are both good heads. I think the flow numbers were quite a bit better for the P heads then originals. We ran a set on our limited modified for a while...good set of heads. There on a 351w right now in another limited mod.
