Old 10-14-2014, 05:28 PM
Cobra Make, Engine: Classic Roadsters, 95 EFI 5.0
Default bump stop for the gas pedal arm?
Should there be a bump stop for the gas pedal arm so that it does not go all the way back and hit the firewall?
Old 10-14-2014, 06:06 PM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
Should have some type of throttle stop that you can adjust.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
Old 10-14-2014, 07:07 PM
mickmate's Avatar
We use a threaded adjustable stop to stop the arms getting cranked around on the shaft.
Gas Pedal per OEM Specify [427 CSX CCX KMP ACE HT] - $250.00 : Acton Custom Enterprises, Custom Metal for Cobras
mickmate
http://www.actoncustom.com/
Old 10-15-2014, 09:30 AM
Double Venom's Avatar
Mickmate,
CR's have a proprietary pedal box with a plate for the pedal stop built in. Wisconsin snake needs to copy what WBulk has shown. (W.S. your pedal box is great for "heel/toe" driving if you ever get into racing!)
Display Modes
