November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 04-08-2016, 11:32 PM
Cobra Make, Engine: Classic Roadsters Chevy 350
Default GM T5 bellhousing
Hello all, my CR is currently running a SBC with T5 trans. Apparently I have the bellhousing for a 3rd gen Camaro because my trans is mounted with the 15-20 degree "tilt" or rotation. Does anyone know of a bellhousing part number I could use to correct this and center up my shifter? My shift boot ring sits right on the curve of the trans tunnel (yuck). Starter is on the RH side and I have an externally mounted slave cylinder on the left. Thanks!
Old 04-11-2016, 11:32 AM
YerDugliness's Avatar
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
IIRC the Chevy Astro van also used the T-5 tranny...you might check the bellhousing for that application.
Hope this helps!
Cheers!
Dugly
YD,E./PNB
No names were changed to protect the innocent!
Old 04-11-2016, 07:44 PM
Thanks for the heads up. Apparently my options are a T5 bell from an 80's S10 before they switched transmissions or a pre 1967 4speed bell. Seems like the S10 ones are impossible to find since they only used the T5 for a couple years. The 4speed ones are all over ebay
Old 04-11-2016, 10:15 PM
Thor maine's Avatar
Check out Advanced Adapters they have or make adapters to fit anything to anything.
Old 04-12-2016, 08:25 AM
CHANMADD's Avatar
This works great.
New Chevy Bellhousing Kit Cover Clutch Fork Throwout Bearing GM 621 11" 3899621 | eBay
...Have to drill the holes out where the tranny bolts to it .....If you use a NWC you will need this spacer too
Bellhousing Adapter to Put A'84 '92 S10 T5 onto A 1955 Up Chev Bellhousing | eBay
Old 04-12-2016, 05:02 PM
Thanks for the info!
Old 04-12-2016, 08:56 PM
CHANMADD's Avatar
Hey...... You're going to need this Bracket and Slave cylinder too......Excellent quality.....Great people
https://www.novak-adapt.com/catalog/...hcr3/kit-hcrc/
The fork that comes with the bellhousing works just great..
Old 08-24-2016, 10:15 AM
Cobra Make, Engine: Hunter, 400cid CHEVY...no Remorse
I also have the T5 from a TransAm of that vintage. I just used a normal Chevy Scattershield/bellhousing and a hydro through out bearing. I did however have to make a rear mount bkt to convert the trans mount to horizontal.
