January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 11-13-2017, 06:44 AM
Default CR parts help
Hi,
I need help as some parts of my CR have to be replaced
brake master
gas tank
gas tank sender and seal kit
gas pedal
holley carburator seal kit
thanks !!!
Old 11-13-2017, 08:29 AM
G_Edmonds's Avatar
Cobra Make, Engine: Classic Roadster, 408 LSX
I think most people use an early 70's corvette brake master cylinder.
I recently changed up my fuel system. The fuel pick-up and sender looked just like yours. I just cleaned up the float, cut off the rusty fuel tube and added another. (Actually put an in tank pump in it.) I was surprised that the tank was very clean when I opened it up. The tank is not sourced from another vehicle so you would have to find something that fits or have one made if yours is bad. Just buy some cork gasket material and cut out a sender seal. A carburetor rebuild kit for your model Holley should have all the seals you need.
Good luck.
-Greg
I've spent most of my money on cars and women. The rest I wasted.
Old 11-13-2017, 08:33 AM
Many thanks Greg, as I don't have any spec of car, is it a Holley 650 ?
Old 11-13-2017, 09:25 AM
Cobra Make, Engine: Classic Roadsters, 95 EFI 5.0
I don't think a specific one was used.
If you pull the carb, there should be numbers on it identifying which one it is.
For the gas tank, as said it was made specifically for the CR.
There are "gas tank coat" stuff you pour into the gas tank and swoosh it around. It creates a seal inside the gas tank. Por15 makes one and it's meant for old tanks.
http://qr.por15.com/QR-assets/downlo...TankSealer.pdf
Thinking about it, I might do this to my tank.
Old 11-13-2017, 06:20 PM
Cobra Make, Engine: Classic, built in 1991 has a 351 Windsor single 4 bbl.
Default tank sending unit
Use the search box to check on your questions, but I went through my gas tank and pulled the sending unit and just cleaned it up and reused the unit. Later I found, while searching, that the sending unit is GM and most likely a Chevy Chevette unit. Make sure you get a good ground on that sending unit or it won't work.
Old 11-13-2017, 06:54 PM
joyridin''s Avatar
On the choke horn, the carb will have a list #. Copy that number and you can look it up on Holley’s web site. That should be an easy rebuild.
The master does look like an early Corvette style. If you have manual brakes, it would be an early 70’s version. You can pick them up cheap. I think I paid $15 for thr rebuilt one from the auto parts store last time I bought one.
Old 11-14-2017, 02:57 AM
many thanks...
the master has this serial stamped #5460346 and it seems to be DELCO 18M72/19176100
the tank I will make with Tankerite or POR15 and will try to fix sender
for carburetor I found CJPony Holley Carburetor Rebuild Kit 4160 Series 4V... will be suitable ?
gas pedal... any suggestion ?
Old 11-14-2017, 05:42 AM
joyridin''s Avatar
I do not know about the number, but it has a large bowl in the front and rear, so it has to be from a GM car with 4 wheel disk brakes. I will put money on it that it came from a Corvette. Go to Rockauto and look up a 1972 Corvette with manual brakes and you will see quite a few options. The are in the mid $20 range.
You will need the list number to buy the correct kit unless they are selling a super generic kit. You carb is pretty nice since you have metering blocks int he front and rear. You might want to pick up a set of jet extensions for the front and rear and a cam kit. You can really make them run with a bit of fiddling.
https://www.holley.com/products/fuel...parts/122-5000
Old 11-14-2017, 07:09 AM
You are right, for master cylinder I can save $50...
For carburetor, model should be near choke housing but couln't find yet...
On valve covers there is M/T, what does it mean ? Air filter seems a bit small ?
Old 11-14-2017, 07:35 AM
Default valve covers
M/T = Mickey Thompson, racing parts.
Old 11-14-2017, 09:12 AM
carburetor is Holley 4777-3 1281, 4150 650
any idea where to find stewart warner fuel sender Ohmic Range: 240 - 33.5 ?
Old 11-14-2017, 09:48 AM
cycleguy55's Avatar
Holley kit for 4777-3: https://www.holley.com/products/fuel...t/parts/37-485
240 / 33 fuel level senders - take your pick, but note none have provisions for fuel pickup tube: https://www.summitracing.com/int/sea...illocation=int
Brian
Old 11-14-2017, 10:30 AM
I cleaned pickup tube as it's custom made, sensor is screwed to plate I would have to check lenght and curve
On sensor I have this part #835400-1 but couldn't find, gauge is SW so should be 240 / 33
Old 11-15-2017, 08:32 AM
[quote=wanab65;1432804]Use the search box to check on your questions, but I went through my gas tank and pulled the sending unit and just cleaned it up and reused the unit. Later I found, while searching, that the sending unit is GM and most likely a Chevy Chevette unit. Make sure you get a good ground on that sending unit or it won't wo
Old 11-26-2017, 04:35 PM
Cobra Make, Engine: Classic roadsters ll
Hi I used a 1975 5.0 mustang master cylinder on my cr car done part # 10-1602
Old 11-28-2017, 04:32 AM
Master cylinder was from C3 Corvette, brake hoses from 1978 Mustang II
I had my tank fixed with Tankerite
Fuel level sending unit I found on Ebay Datcon type, 240-33 ohms, 6”- 24” adjustable
as gauge is from Stewart Warner and hope would work
now I have to replace all shock absorbers and rubber bushing
any idea about gas pedal ?
