01-25-2018, 04:05 PM
Tx
Cobra Make, Engine: 302. 1992 build
Sway bar
Just took that big fat 1.25inch bar off my c r cobra the ride improved quite a lot.Still corners great and suspension can move better. May take rear off just to see if any difference any input from any is welcome.
01-25-2018, 08:21 PM
Cobra Make, Engine: Unique 289 FIA
I think you will be better off putting one back on,1.5" is pretty big-I have a 7/8" front and 5/8" rear on mine and the ride is fine. Rich
Unique FIA Cobra with 289 and Toploader
Sold:MK4 Factory Five 4.6 SC
MK2 FFR 408W
MK2 FFR 345HP Crate 302
Superformance BB460
01-26-2018, 05:25 AM
I concur that 1.25" is a rather large sway bar for such a light weight car. I am not surprised that the handling was poor. If you decide to put sway bars back on, I would go with a smaller size.
01-26-2018, 08:51 AM
Tx
Sway bar
Thanks guys for the input on bars will think about going with smaller bar.
01-26-2018, 01:58 PM
To balance the car with that front bar, you need a 7/8" rear bar. Then you will be ready for a track day.
01-27-2018, 06:42 AM
Tx
Cobra Make, Engine: Classic Roadster, 408 LSX
The front sway bar you removed from the front was from a full size bronco. CR used it because the dimensions were right. Well meaning advice from owners of other makes while appreciated does not apply to our cars. There are good threads about this in the CR forums. With a small block your car will ride better and handle better without a front sway bar. Unless it's getting to be a serious track car, you're better off without the rear bar too.
-Greg
I've spent most of my money on cars and women. The rest I wasted.
01-28-2018, 11:52 AM
Tx
Sway bars
Thanks to all for feed back on sway bars.probably won't track car although it would be fun ,may remove rear bar also and see how it rides thanks again guys.
01-28-2018, 11:58 AM
Tx
G Edmonds Bulldog here I have brother -in- law who lives in Longeview i plan on a drive down there in the near future maybe we can meet up. Talk cobras?
01-28-2018, 12:08 PM
You definitely need to take the back bar off if you are not replacing the front-it will cause too much oversteer. My recommendation is a 7/8" from and a 5/8" to 3/4" rear,and you should be fine. Without bars I think it will sway back and forth too much. Rich
MK2 FFR 408W
Superformance BB460
01-28-2018, 02:56 PM
I notice without the rear bar and still using the original front bar my rear end articulates a lot more causing inside tire rub in certain situations...usually pulling in or out of driveways. Thinking I should put the rear bar back to tighten things up. I changed my rear lower control arms to an adjustable tubular type and so to install the rear bar I need to fab someway to attach it. Would the lack of a rear bar cause understeer?
01-28-2018, 04:01 PM
Yes,it probably will-but it is safer than snap oversteer. It would be worth the time to mount a rear bar-but at least you can drive the car with only a front bar. A lot of guys on here only have a front bar-my car for the first 14 years of it's life included until just recently. Rich
MK2 FFR 408W
Superformance BB460
01-28-2018, 06:16 PM
Tx
Sway bars
Bulldog here again great feed back from everyone that is why am glad I found this cobra site
01-31-2018, 07:15 AM
All,
In the middle of finalizing the chassis from my 1990 CR originally built and now finalizing the roller chassis.
I fully agree that the front bar is way too large for this car.
My question is: Where did you locate a 7/8 front bar that will fit our cars? I have converted the front suspension to Heidts tubular and QA1 coil overs. The Hiedt lower arms have mounting points for sway bar with downlinks.
Any help in locating a smaller front bar would be greatly appreciated.
03-01-2021, 08:08 PM
BC
This is a bit of an older thread, but I’m also curious what other front sway bars out there will fit these cars??
Anyone who has replaced theirs care to share?
Michael
03-01-2021, 08:57 PM
Yeah, I'd love to know where everyone found the right bar...
03-02-2021, 11:29 AM
wa
Look at other posts for suspension. Double Venom references them. Pretty sure it's tied to the coil over ones.
03-02-2021, 11:44 AM
Cobra Make, Engine: NAF 427
I used an MGB front sway bar, 7/8" -23mm, which, width wise, fit the front tubular lower control arms perfectly. Assembled my own links and used aftermarket/e-bay poly bushings and mounts for the sway bar to frame mount.
Greg
03-02-2021, 01:07 PM
BC
Great info Greg, thank you. What year MGB was that? Any chance you have any photos?
Cheers!
Michael
03-03-2021, 12:26 PM
Hi Bulldog and MGM. The best source for info to begin with for the MGB front sway bar is Moss Motors, then e-bay. Lot's of info out there.
Moss Motors 7/8" front sway bar for all MGB's is the same for 72-80 and part number is 454-955.
Lots of used stuff on e-bay.
Here are a couple of pics.
Greg
03-03-2021, 06:20 PM
Cobra Make, Engine: FF Mark I, sprint car 347
Hi-If street use no sway bar front or rear. If IRS it is a toss up. Not my opinion but from a very reliable source (Gordon).
