January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Like Tree1Likes
  • 1 Post By Bulldog
Old 03-08-2019, 08:25 PM
Cobra Make, Engine: 302. 1992 build
Default Temp gauge
My temp gouge needle goes to the hot side with key turned to on ,it went back to normal then backto full hotwhat gives?it is a c r l. . l gauge. It must be broken . Bulldog
Old 03-09-2019, 05:44 AM
Ron61's Avatar
Check the wiring, especially for grounds. If that is OK go to NAPA or some parts store and buy a gauge that you can use in your hand and hook it onto your sensor and see what it does. If it reads OK then you have a gauge problem or a wiring problem at the back of the gauge. If not your sensor could be going bad. By it acting the way it does when you first turn the key on I would suspect a wiring issue.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 03-09-2019, 09:28 AM
Default Guage
Thanks Ron I will try it Bulldog
Old 03-10-2019, 12:23 AM
also you need to know range of your sensor if electrical, not all sensors are compatible with all gauges. the gauge will have a specific ohm range required.
Old 03-11-2019, 12:38 PM
Default Guage
Thanks 74proii will Ck that. Bulldog
Old 04-09-2019, 07:24 PM
Default Temp guage
Last post my. Temp gage was acting up needle bouncing. Aroundthought it was sensor then gage but found problem I had distributor out of car when I reinstalled it the bottom of distributor was touching water temp sensor just barley but it caused a short . Bulldog
Alfa02 likes this.
