Old 05-08-2019, 07:10 AM
rbgray1's Avatar
Default Coolant expansion and recovery tank
Hello All,
I"m back in the rebuild process of my CR1. Plumbing brake lines and getting the engine reinstalled with new clutch and refreshed transmission.
I am interested in what you guys are using for coolant expansion and recovery tanks? The original CR1 only used a high mounted radiator cap in the upper hose and had no provision for coolant expansion/recovery, just used the fill neck and fitting to allow expansion coolant to flow onto the ground.
I'm not sure if I can use one of the factory style cobra tanks(Mid 60s Ford) that mounted on the intake manifold due to the fact that I'm running March billet pulley drive system and the factory style Ford expansion tank will interfere with the March bracket system.
What are you guys running for coolant recovery / expansion tanks?
Canton Racing Tanks?
