5Likes
11-03-2021, 06:31 AM
Shocks + Clutch Set
gents...
progressing on the new build.
here are pictures related to my Shocks (plus springs?) + Clutch Set modernization project....
would appreciate your part related recommendations, if possible, with links to spare parts to be bought ideally from Summit Racing and if not, from another supplier
the goal is daily street / comfortable drive
many thanks in advance
11-03-2021, 06:56 AM
More pictures here
11-03-2021, 08:59 AM
WA
Artur, rear is not Fox Mustang. Top mount is different. Front is longer than Mustang II. Are there numbers on the shocks we can cross reference? It would be helpful to get compressed and extended lengths of shocks. As far as brand I like KYB. The clutch we need the diameter of the clutch disk. What engine? Small block Ford, FE, 460 or SBC, BBC?
Jim Nichols
11-03-2021, 10:05 AM
Thanks Jim — all measurements will be out tomorrow
It’s a 351windsor small (!) block — I think with the last machining, it got little bigger
11-03-2021, 10:22 AM
WA
Artur, One more measurement, 1 1/16" 10 spline or 1 1/8" 26 spline input shaft. What transmission? T5 5 speed or Toploader or Borgwarner T10 4 speed. HTOB or conventional clutch fork?
Jim Nichols
11-04-2021, 12:46 AM
Here we go with the answers:
- I am getting the shocks locally, so that’s under control for now…I have a question though — does it need to be 1-1 replacements of the same shocks ? Isn’t there a possibility to just recommend a shock that would fit well regardless of what is currently on it ? And if that’s the case, what shocks are guaranteed to fit and good to recommend ?
- clutch disc diameter: 10 inch
- 0.98 inch and 1.18 inch are the measurements you asked for spline
- engine 351w
- gearbox picture attached - I believe it’s a t10 ?
- you are asking a question about clutch type, am not sure about the answer. I’m sending you clutch disc and clutch plate pictures
11-04-2021, 04:50 AM
WI
Your trans is a T5 with an aftermarket bellhousing/ scatter shield. That looks like a stock clutch disc for a Ford T5. Make sure you inspect the shaft bearing the is pressed into the hole in the center of the flywheel. Nice time to replace it. If it is worn out or missing you will have driveline vibrations that will destroy the trans. Also inspect the throw out beating- it is mounted to the clutch fork and slipped over the input shaft of the trans (sorry if you know this, not trying to be anything but helpful).
Thom
11-04-2021, 05:01 AM
WI
There is a tag on the trans (I circled it in the photo). Get a photo of the tag numbers and I can decode the model of the trans for you.
Thom
11-04-2021, 06:13 AM
i am having trouble sending pictures
the numbers i see on trans
10233
M0512
13-52-202
11-04-2021, 12:00 PM
WA
Looks like 10 splines on the clutch. If you are sure it is 10". 10.5 is more common:
https://www.summitracing.com/parts/mcl-75213/make/ford
Take the thick rubber spacer off when you check the front shock compressed length. The rear are Gabriel Red Ryders. The number on shock will help me identify them. I can tell you what you need if I know the compressed and extended lengths. I'd crossover to KYB Gas-Adjust.
Jim Nichols
11-04-2021, 12:27 PM
WA
1352-202 T5 # is WC SVO, 2.95 first and .80 OD fifth. A very good T5. Must use ATF fluid. A little under 3 Qts.
Jim Nichols
11-04-2021, 12:54 PM
WA
Jim Nichols
11-04-2021, 06:49 PM
WI
He is correct:
1352-202 Ford SVO WC (Aftermarket)
U(CODE) Gears- 2.76 2.9 1.94 1.34 1.00 0.80
(Reverse) 1st 2nd 3rd 4th 5th
11-07-2021, 01:23 AM
All noted with thanks
I am going with local supply of shocks and clutch set
Brakes are ordered as discussed earlier based on the sets you sent earlier with master cylinder 1inch as Jim recommended
12-18-2021, 01:32 AM
Hello everyone
Like to report back some progress and one field I'm lagging behind
Brake system - fully replaced thanks to all support I received from the forum
Clutch set - done all with original parts sourced locally
Shocks -- plan was to source also locally but we got wrong shocks
I like to give the dimensions that Jim Nichols asked last time:
Front open: 17 inch
Front close: 13.4 inch
Front: black color shocks
Rear open: 17 inch
Rear close: 11.8 inch
Rear: red color shocks
Unfortunately no part number marked on shocks.
Only thing we see is a "red Ryder" logo on rear shocks
Appreciate your thoughts
P.s. the local supplier suggested we try a second order of Monroe shocks based on these dimensions....any idea about Monroe ?
12-18-2021, 01:40 AM
Before I forget I also need these rubbers
12-18-2021, 06:24 AM
Cobra Make, Engine: ford 302
Do you have a copy of the build manual? It has many of the basic parts and where they come from
12-18-2021, 09:30 AM
WA
Artur, Rubber front spring isolator is Mustang II. I'll check KYB for shock dimensions.
Jim Nichols
12-18-2021, 09:41 AM
ON
Cobra Make, Engine: classic roadster '92 build Cleveland 351
monroe part # from build manual
Artur -build manual part # for front shocks Monroe #2067 or Monroe gas #5815
12-18-2021, 09:45 AM
ON
The build manual I found says front shocks are Monroe #2067 or Monroe gas # 5815
