12Likes
4
Post By 440.mustang
Post By incoming
Post By 440.mustang
Post By markantioch
Post By sunman
Post By 440.mustang
Post By Harpoon PV2
2
Post By 74proii
05-08-2022, 07:42 PM
Oh
Cobra Make, Engine: Classic roadsters 1991
Cobra progress
Back from paint, wired up almost complete, detailer is coming to do a final buff on it so I can install windshield, sidepipes and rest
05-09-2022, 03:28 PM
Ok
Couple more hours. :-)
Looks great. Did you make motor mounts or use the Classic mounts? C6 fit ok? Once you go big block its hard to go back.
 Chaney Shores Studio
05-09-2022, 03:30 PM
al
I like it when a plan comes together.
05-09-2022, 05:35 PM
Cobra Make, Engine: Classic Roadsters, Ford coyote Gen1
That intake setup is going to starve that engine of fresh air. Replace the lid with a filter lid.
Mark
05-09-2022, 06:41 PM
Oh
Aircleaner
Not much room between hood and aircleaner cover, I had to make the base to sit low enough
05-09-2022, 06:43 PM
Oh
We used the factory mounts fron classic roadster, has a c6, its going to get a 4 or 5 speed this winter
05-09-2022, 07:09 PM
Oh
Aircleaner
Aircleaner
05-10-2022, 11:45 AM
wa
Is it bad when you notice the door jamb switches and center mounted courtesy lights ......
05-10-2022, 08:21 PM
Mark
05-11-2022, 08:44 AM
Ok
What motor mount bolts to the motor? Building some in stainless from photos in the manual, can you get size of the rectangles maybe up under there?
The motor in my bus turns out to be a fresh 390 .040 over with C5AE heads.
Gotta use it rite.
I think Farmtruck and AZN will end up with the party bus and it will get a 632 and be on TV racing the Okla State Pen Green Lizard.
What about headers?
What’s this huge round thing on this C6 tailshaft?
Party On
05-11-2022, 11:31 AM
Oh
Engine mounts
I have a set of mounts that bolt to classic roadster frame, I'll get a pic of both small block and fe mounts,
05-11-2022, 02:23 PM
Oh
Mounts
Bottom angle is 8.625 end to end Chanel is 3 7/17 x3" hole is centered 1/2x1" slot 4 1/4 from angle to top of chanel
05-11-2022, 02:25 PM
Oh
Mount
More pics
05-11-2022, 05:52 PM
Ok
Thanks, I have searched a long time for the numbers.
I found a place that will electropolish at a reasonable price, these stainless parts will shine like chrome.
They will look good with the chrome spray painted a-arms…
Looks like the FE 2290 rubber mount.
Piece of cake thanks again.
05-30-2022, 07:26 AM
Oh
More progress
Getting closer, need wheels and tires, anyone have a set to get rid of??? Just a few things left, carpet on firewall and kick panels, wire up led backup lights on license plate, get i finish buffed and polished...
05-30-2022, 06:52 PM
WI
I would say "OCD" but that is out of sequence- it should be "CDO"
05-30-2022, 09:59 PM
I am getting more and more, where I like the C6 in a Cobra! As you know, Carroll seemed to have had a thing for that combo also. Besides the Super Snake, he had, I believe two different 428s with C6s, which he heaped praise on. He also had one, maybe two MKII small blocks with the same. When it came time for his last ever Cobra, a CSX8000, well you already guised it! No one can argue with Shelby's shifting prowess, safe to say, he shifted more gears then about anyone here! Cheers, Dennis
05-31-2022, 11:40 AM
wa
At the time is was the strongest, although heavy trans available. Today that isn't the case, very slight mods to a C-4 results amazing results. Yes people will argue the pros and cons all day long. Then someone will come along with a Poweglide has less drag/ is better blah, blah, blah. Either way it will be great as long as you don't put a useless GM paperweight in it.
