| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
09-16-2002, 05:09 PM
ca
Cobra Make, Engine: classic roadster, 302, dual carbs
steering column wiring help
I posted in the shop talk area about the id of wires in my steering column plug any help would be appreciated. I'm not sure if I have a classic or not any specific areas I should look?
09-17-2002, 05:23 PM
VA
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Describe what you have, so we can have a look.
09-18-2002, 04:12 AM
ca
I posted this in the shop talk area..I'll have to retype because the computer wont copy and paste it:
I figured i would start from scratch and rewire my cobra. I bought an ez wiring kit and proceeded to rip all the wires out of the car.when I got to the point of attaching the steering column ignition turn signal switch i ran into a problem. the diagram that came with the kit shows differant wiring colors. Since I dont know what the donor car was I have no idea which wiring diagram I need to look for. The ignition and turn signal switch seem to be all in the same plug. It is shaped like a 1/4 of a circle top three wires are:
2 green/white striped wires(in same socket)
2white/blue stripe wires (same socket)
2 blue
bottom 6:
black(grey?) with purple dash
blue/dark blue stripe
orange/blue stripe
green/red stripe
white with red dashes
yellow with grey(black?) diamonds
anyone know what these wires are connected to ie ignition/turnsignals?
thx for the help
09-20-2002, 11:21 PM
ca
OK as it turns out I thought the turn signals and ignition switch were connected together.Now I know the ignition switch is on top of the steering column IN the ENGINE compartment. even still I come up short on the wires that are in the car.Anyone have a wiring diagram they could e-mail me? pretty sure its a 74-77 mustang.
09-21-2002, 12:56 AM
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
It sure sounds like a M2 harness, so here goes:
Light green/White is Left turn signal
White/Light Blue is Right turn signal
Dark blue--horn
White/Red=emergency flasher
Yellow/Lt Blue=power
Lt Green/Orange Left rear ts
Orange/lt blue =RR turn signal
On the front, you may have 2 wires coming out--one to the signal bulb and one to the indicator bulb on the dash.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
09-21-2002, 10:03 AM
ca
hey thx for the help !!!! thats just what I needed .I have two wires left... light blue with a dark blue stripe , black with a purple dash and theres actually 2 dark blue conected at the same point. would the horn have 2 wires? also what year car has the m2? hey THX again.
09-22-2002, 03:37 PM
The Mustang 2 was 74-78, all wiring the same, as is the Pinto. the horn is 1 wire, dark blue.
