Like Tree3Likes
Old 06-15-2003, 10:45 AM
fxbill's Avatar
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Default Footspace
I have a CR that was originally setup for a big block....I have a stroker 351W installed instead. The pedal arrangement stinks. There is so little room where they are that you need to hold your foot up above the clutch pedal the whole time you're driving or slip it up and under the clutch pedal because there is ZERO room to the left of the pedal. The bellhousing hump is so wide that there's nearly a foot of clearance to the transmission on either side and the throttle pedal almost rubs the hump on the inside.
Has anyone found a reasonably easy way to modify the footspace in one of these to allow the pedals to be offset enough to give a little space to the left of the clutch and rest your foot when driving?
Thanks for any help!
Bill
Display Modes
