Old 09-04-2003, 07:56 AM
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
Angry Cr door hinges
Alright, alright, how many of you CR builders have put your door hinges together backasswards and then spent a whole day trying to get your doors to install?? C'mon fess up so I don't feel like a complete idiot!!!
Old 09-04-2003, 02:25 PM
Double Venom's Avatar
Art,
I know we discussed this and I certainly pleaded guilty...numerous times! I don't know anyone that hasn't done it at least once.
Like I said, when Don, Jay and I get done with the NEW & Improved Manual it will be much easier to tell which whay they should >point<.
Hey don't feel bad yet, you've got a lot of boo-boo's infront of you!
DV...Oh-Ya, the old "been there done that" routine!
Old 09-04-2003, 06:33 PM
dscott's Avatar
Cobra Make, Engine: Owner, Classic Roadsters II
Art, sorry, I had a good laugh. I have done it more times than I care to admit. I looked at a trunk hinge for about an hour once trying to understand how to get the hood mounted to it. Of course this was before I became an expert!!! Now I only have to look at it for a few minutes!! Are you sure you didn't just have the right hinge on the left side. They're easy to mix up since they are both the same.
Don
Old 09-04-2003, 08:21 PM
Don the damn doors are on arghhh! Don't start this left side right side stuff or I won't be able to sleep at night Har har.
Old 09-05-2003, 09:39 AM
dscott's Avatar
You know what they say, righty tighty, lefty lucy ! Are you sure you have the hinge pins right side up, if you don't the doors will open upside down
Don
Old 09-05-2003, 05:17 PM
Slow Dawg's Avatar
Cobra Make, Engine: 2 Seat Roadster-by B&B, 460+ w/auto.
Talking
Actually Don, if you look at them long enough and go cross-eyed, they will open in and not out!
Nonconformist. Can't handle a real job.
Old 09-06-2003, 08:20 AM
Don,
I had three shims on each door to move it back far enough,then
while sitting on my milk crate and staring into space(I do that a lot nowadays),I noticed the bolt for my steering column mounting was hitting the defroster plenum which was holding body about 3/4 " back from where it should be. Fixed that and now doors fit real good. Man I thought sanding the body was tiresome,this fitting and fixing is a real pain in the tukus. Oh and put in the "new" manual that the door latch opening should not be cut out until you're mounting the doors. I cut mine where indicated
and guess what? Wrong position! Now I have to re-glass entire area and start over again.
Display Modes
