November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 01-01-2004, 08:12 PM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Sounds like BC has the easy solution.
Brake and clutch pedal pads look like standard auto supply store variety (Help, etc.) of standard e-brake foot pedal pad replacements.
Throttle cable. Used standard Lokar street rod cable throttle with speed shop throttle cable - carb bracket.
A suggestion before installing the pedal assembly would be to use better bearings on the cluch pedal cross shaft, even re-working it for ball bearings. Mine are getting sloppy already.
Display Modes
