Old 07-19-2004, 08:11 PM
jdean's Avatar
Default Trunk release on a CR...opinions
The CR has no room for the traditional trunk handle, since the license plate goes to the bottom of the trunk lid.
Has anyone seen one mounted like this, from John Polings gallery? This is not a CR, but has the same license plate situation.
http://www.clubcobra.com/photopost/s...cat=500&page=4
So.....Don Scott.....anyone.....what do you think of the looks of the handle below the trunk? or should i just go with a remote release?
Old 07-19-2004, 08:16 PM
Bruce Edwards's Avatar
Cobra Make, Engine: Hunter with a 4.6 supercharged
John,
We mount the handle under the plate but us an electric remote system to open the trunk. Looks like OEM but the handle does not work. We trim it off on the back so it sits flat on the trunk lid you just can not turn it. You can still use it to lift the trunk lid.
Looks like this.
http://www.clubcobra.com/photopost/s...cat=500&page=1
This is a Hunter kit but you get the idea.
Bruce Edwards
Gemini Motorcars Inc.
http://home.bellsouth.net/p/PWP-GeminiMotorcars
Old 07-19-2004, 08:25 PM
jdean's Avatar
Bruce,
On my car, there is no room under the plate to mount the handle on the actual trunk lid, so the "dummy" handle would not lift the lid.
But I like your idea.
6th generation Texan....
Old 07-19-2004, 08:57 PM
relaxinrob's Avatar
Cobra Make, Engine: FFR Daytona Coupe done to replicate CSX-2299 at the '64 LeMans
Mine has a remote latch with a choke-type cable that activates it from behind the driver's seat. It locks it also. I can get an extra latch setup like mine if you need it.
Replicas are the highest form of flattery!
http://www.rehobothproperties.com/coupe.htm
Old 07-20-2004, 05:03 AM
John,
I have seen some folks cut the plate around the handle. If you do this you can not us a plate holder such as the one on our car. We us an electric poper to operate the latch. The last CR we did we put electric popers on the doors hood and trunk. It is great fun at shows for the guy that owns it. Someone gets to close to the car and he hits the button on his key pad in his pocket and a door pops open. Folks think they did something and jump back from the car.
Bruce Edwards
Old 07-20-2004, 08:59 AM
dscott's Avatar
I like the look of the handle on the body. You could make it functional also. If you want to use an electric opener Watson's Street Works has a nice setup. www.watsons-streetworks.com.
Don
Old 10-10-2004, 03:17 PM
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
I mounted two handles one on either side of the license plate. Neither is funtional except to use as a handle to lift trunk. The lever supplied with the kit works just fine for me.
Old 10-10-2004, 03:24 PM
Ron61's Avatar
Post
John,
I used a set of billit openers that I mounted on the upper left hand side of the drivers compartment. They hang down enough for me to pull them. One opens the trunk and one the hood. Doesn't look original but neither does any of the rest of my car.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 10-11-2004, 08:38 AM
McCobra's Avatar
Cobra Make, Engine: Classic Roadsters 427 C/O w/ Dual Quads
relaxinrob,
Where did you get your lockable cable release for your trunk?
Thanks, Mike
Old 10-11-2004, 01:30 PM
relaxinrob's Avatar
It came with my kit. My dad got one with his kit too, but he used a regular handle. I think he wants $30 plus shipping for it. You use a choke cable to activate it.
Old 10-11-2004, 02:28 PM
McCobra's Avatar
Any chance of getting a picture of it?
Old 10-17-2004, 10:48 AM
jdean's Avatar
I posted some pics on my gallery. I decided to mount the traditional style trunk handle below the trunk lid. When the handle is closed, the hook grabs an eye bolt that screws into the trunk lid. On the CR, a metal plate is made into the fiberglass trunk lid where the latch mounts to the lid.
This was good, since I was able to drill and tap it in order to screw in the eye bolt, making it adjustable.
I think it looks good, and it works too!
Old 10-17-2004, 11:49 AM
HI Cobra's Avatar
I went with the lever down under which works fine.
You can't see it and I don't have anything in the
trunk on a constant basis, so I am not worried
about the lack of security. To date, nobody has
asked where the trunk handle is, and when
raising the lid I just lift on the bottom edge of
the lid. I was going to use an electric actuator
like I used on the doors but as much as I use
the trunk decided to go with the KISS system.
Flip
