Old 02-21-2007, 04:42 AM
coosawjack's Avatar
Cobra Make, Engine: Classic Roadsters '66 427 Replica-SOLD
Default Drive Shaft Loop??
Hey Don,
I've read a few threads about broken DS yokes under power and got an ugly image of what might happen to me if that happened!!
Do you have a loop for our cars and if so will you need the chassis number or have they remained the same through the years??
Thanks in advance!!
Coosawjack
Old 03-04-2007, 04:18 AM
coosawjack's Avatar
Bump??
Old 03-04-2007, 08:43 AM
petek's Avatar
coosawjack,
I just used a hoop from Summit Racing. Worked well. Pictures and info over at my web site: http://www.birch.net/~petek/cobra/007/jul1.htm
Pete K.
Who is John Galt?
Old 03-12-2007, 02:35 PM
dscott's Avatar
jack, the way the rear tunnel for the emergency brake is setup it will act as a driveshaft loop towards the top of the car. If you want to you can add a strap between the frame rails under the driveshaft to keep it from dropping to the ground.
Don
Old 03-13-2007, 03:16 AM
coosawjack's Avatar
Thanks Don......I'll take a look at it!!
I was thinking that if the rear U-Joint broke the shaft would likely just fall out but if the front one broke it could flail around and possibly come through the tunnel??
Coosawjack
