Old 08-12-2007, 09:50 PM
Default Lower radiator hose
I bought a Griffin radiator setup from CRII. The bottom outlet is on the passemger side and my waterpump inlet is on the drivers side. Anyone with this combo? Has any one made up a pipe that fits so you only have to put the rubber hoses on the ends to connect the water pump and the radiator?
Thanks, Terry
Old 08-12-2007, 10:32 PM
cab cab is offline
Cobra Make, Engine: hurricane,# 1060
I had to do this for my car,check my galley for a pic..
www.tni.com/craig-baker
Old 08-13-2007, 06:25 AM
Juggernaut's Avatar
Cobra Make, Engine: RUCC, 289 c.i. with a T-5 "Living the Cobra Experience"
Terry, I have the same type of set-up on mine, I used the Cool Flex metal hose, worked great!
Juggernaut
Old 08-13-2007, 08:51 AM
Cab,
Looks fairly simple that way.
Juggernaut,
Would you happen to have a part number and a place where I can check it out?
Thanks, Terry
Edit: Checked out the Cool Flex web site. Nice looking stuff.
Old 08-13-2007, 08:58 AM
capteddie's Avatar
Cobra Make, Engine: CRII 351W/408 Stroker
Send a message via AIM to capteddie
Here's a link for the coolflex site
http://www.coolflex.com/cfm/welcome.cfm
Ed
Old 08-13-2007, 08:59 AM
Thank you Ed
Terry
Old 08-19-2007, 05:55 PM
MaSnaka's Avatar
That coolflex site is nice. Good looking stuff. What color combo would you go with? I'm thinking blk/blk. Or blk hose/ silver connectors. Those are on my wish list.
Old 08-19-2007, 08:41 PM
Rick Parker's Avatar
Here is a fabricated lower "Hose", it works perfect.[IMG][/IMG]
Rick
Old 08-26-2007, 10:08 AM
Rick,
What is the fitting on the top of the fabricated alum tube for?
Terry
edit: corrected spelling
Old 08-26-2007, 07:30 PM
To burb air that is in the upper part of that tube/hose as it fills. I also put one on the uppermost corner of the radiator. It allows any and all air to be removed prior to putting the cap on the surge tank.
Rick
Old 08-27-2007, 03:53 PM
Thanks Rick, Terry
Display Modes
