Old 04-15-2008, 07:28 AM
Cobra Make, Engine: classic roadsters II, 351W with about 400 hp
Thumbs up To anyone who needs the fuel pick/sending unit!!
To anyone in needs of the fuel pick up/sending unit for thier CRII.
I found this unit for sell at www.classicinstruments.com
part # SN33, direct link below.
https://www.classicinstruments.com/p...oductCode=SN33
Fuel Sender - Deluxe Stainless
The Deluxe Fuel Pick-Up Tube Sender (shown at left) features a stainless-steel mounting plate and 3/8" OD (outside diameter) x 13" long stainless pick-up tube (shorten or extend to match your own tank depth).
It includes a cork gasket, five self-sealing mounting screws, and instructions. It is designed with new heavy-duty flat-card technology resistance movement for greater accuracy, reliability, long-operating life and resistance to road-vibrations.
The sensor housing easily rotates a full 360 degrees on the stainless pick-up tube to position the float in any direction to clear internal tank baffles, side of tank, vent lines, etc.
The Deluxe Model is available only with the aftermarket standard 240-33 Ohm Heavy-Duty Sensor Movement at this time.
If another resistance range is required, choose from our Standard Model Fuel Senders shown below.
Display Modes
