1Likes
08-29-2008, 06:20 AM
Mi
Buddy,
My sleep patttern is as normal as ever, it sucks but it is normal. I did make a mistake though, I lost a day, thought this was Saturday- DUH! Actually aiming for a late afternoon startup on Saturday. Just my normal work day,
DV
08-29-2008, 06:43 AM
Mi
Buddy,
Just Heim and Bracket:
Full shaft with new heim:
DV
08-29-2008, 10:12 AM
Mi
Re-modified dash and dash wiring
Cpteddie,
Just so you can see;
Switch #1- Windshield wipers
Switch #2- Headlights
Switch #3 Red - Main power switch
Switch #4 Fan over ride
Right side of column:
#1 Holley Choke-Manual
#2 Ignition switch
Top large gauge - Speedometer
Bottom Large gauge -Tach
Center Gauges:
Top left - Oil Pressure
Top Center - Oil Temp
Top Right - Water Temp.
Bottom Left -Fuel
Bottom Right - Volts
As requested..
DV
ps- your tach & speedo have been switched- gotcha!
08-29-2008, 11:38 AM
IL
Looking good DV...
Sent you a PM about the drive shaft and the tubing.
Let me know if there's anything else you need. Have a good weekend and don't work to much. People are starting to comment on our work habits
"the other ed"
08-30-2008, 05:34 AM
Mi
Cpteddie,
You have FR steering wheel D-FR20130BK, you have the horn button kit but I can not find the necessary adapter # FR20160AD which is sold seperately.
This wheel may take a plastic cover between the adapter and the wheel (?) which is also missing, including a heavy duty spring. Also missing. The fine tooth nut on top of the column which this wheel may or not use is also not available. I do have the six bolts for the wheel but that is all.
A call to FR for the adapter and the necessary parts, if needed, needs to be ordered so we can steer this thing 1800-648-8022, Thank you Sir, your attention to this would be greatly appreciated-unless it is in the shop in a hidden spot again!
Sure would like to steer this baby monster!
DV
08-30-2008, 05:43 AM
IL
Nothing comes up under that part # at FR or Summit.
Not sure if there will be anyone at Fr on a Saturday, but I'll try calling them in a couple of hours.
I have the round center horn disc. Remember you said the logo reminded you of Factory 5 and I said I'll take that with me and see if I can get something a little more custom made, but thats the only piece I took.
"the other ed"
08-30-2008, 08:45 AM
Mi
OK,
The numbers are NOW right. The ....160AD is an accessory part that is needed to mount the wheel. I doubt if Summitt would have anything needed on the accessory side.
On the other side, Chad finally, after over 40 parts found the right adapters to the tranny and I am putting them in now. Stainless #6 to Stainless #10 to the oil cooler.
Sorry about the mistyping.
DV
08-30-2008, 03:59 PM
IL
Well....
Still nothing comes up on Flaming Rivers site when I search for 160AD
I'll call them first thing Tuesday and give them the part # of the wheel and the column and get what we need.
"the other ed"
08-30-2008, 05:37 PM
Mi
Ed
the 160... is the last series of the correct number instead of what I sent you the first time. Sorry if I got confusing. Lets try this one more time:
FR20160AD IS the correct complete number.
You will have to ask them if a large Plastic shaped dish is needed with this column/wheel and that we do not have the "nut" that normally holds a steering wheel on? (I doubt if this wheel uses that type of nut but without seeing the adapter, the mentioned number, I don't know including a heavy gauge spring that is normally used, may not be used with this wheel.
I hope that I have made this somewhat understandable this time!
DV
08-30-2008, 07:00 PM
IL
Gotcha Pal !!!!!
I'll call them first thing Tuesday morning and get you what you need.
"the other ed"
08-30-2008, 07:10 PM
IL
OK DV...
Found this off the last part # you gave me
http://store.summitracing.com/partde...5&autoview=sku
I'll still call FR on Tuesday and see if we're missing anything else.
"the other ed"
09-01-2008, 06:44 PM
IN
I need a roll bar!!!
Just came across your question "anybody need a Roll Bar"I just started searching for the roll bar for my CRII Cobra.....so where do I get one???
Please help!!!
Steve Townsend
Steven L. Townsend
09-02-2008, 03:45 AM
Mi
Steve,
I'm just getting re-started, left, right or a four point? All bars will meet NHRA rules and be 2" DOM material. Working out the cost as we speak with the new prices of steel.
Ordering:
DV
4905 Wayne Rd.
Pentwater, Mich, 49449
1-231-425-6823
H-1-231-869-4608
v10doublevenom@peoplepc.com
Deposits only! No roll bar will be paid for in full until I have them in stock finished and ready to ship.
Stainless, chromemolley are not available but I can get them powder coated for you in any available powder coat color, or just ship them plain.
DV
A true 5-point is available but the cost is rather extensive but the center bar is removable if wanted, MEETS Every racing sanction requirement.
09-02-2008, 09:42 AM
Cobra Make, Engine: classic roadster,408cu
johnbcomp
I am getting some made right now , orig style 2" dom mandrel bent should be done today PM for price..WD
09-02-2008, 11:20 AM
Mi
Wetdog,
I just couldn't wait any longer to replace my stolen equipment. Nice to be able to do it again, but these are certainly not "mandrel" bent! No kinks, but still not mandrel!
Hows your car comiing? Gotta be getting close, hey!
DV
09-02-2008, 02:39 PM
IL
DV
Just got off the phone with Flaming River. The adapter and the missing nut, spring and cam have been ordered. You should have them by Friday.
See you Saturday morning  around 9-9:30
"the other ed"
09-02-2008, 04:08 PM
Mi
Outstandiong! Get out and stretch a little, 3 / 4 hours is long enough on one trip!
DV
09-02-2008, 07:04 PM
Getting close
Yep kids and animals are afraid to go outside with all the noise comming out of my garage .How about a pic of the bars?? WD
09-02-2008, 07:28 PM
IN
Thanks for the quick response, just looking for a standard 3 point in a 2", plain to bolt in the CR II Cobra. Cost and availability, please!!!
Steve
Steven L. Townsend
09-02-2008, 08:12 PM
Mi
Pictures and all will probably be on here before the 19th. ODM is to be delieved tomorrow, gootta do Ed's first thnm katie bar the door!
DV
